Author Topic: Headlights Get Brighter When Revving Engine  (Read 3984 times)
mkeefe
« on: August 08, 2008, 12:00:52 PM »
Forgive me if this has come up before, but my searches came up with little useful information.
 ('77 CB550F) The headlight gets significantly brighter when I rev the engine, then dims down when it's idling at about 1000 RPM. Battery is new this season, rectifier was recently replaced. Is this something that I should be concerned with? Possible causes? Thanks.
Offline OldSchool_IsCool
  • Really feeling like an
Re: Headlights Get Brighter When Revving Engine
« Reply #1 on: August 08, 2008, 12:14:38 PM »
Get a volt meter and measure battery voltage at the following rev points:
- engine off, key off, kill switch off
- engine at idle (1000-1500)
- engine reved (2000-2500)
- engine reved (3000-4000)
- engine reved (5000-6000)
- engine reved (6000+)
- report results back here
If your generator and rectifier/regulator is working right... well... don't want to contaminate your observations!  ;D
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
« Reply #2 on: August 08, 2008, 12:17:47 PM »
First off, to alleviate your fears, in general, that should happen. So now the question is a matter of degree. To determine if it's happening too much, follow Old School's line of questioning.
Offline bistromath
« Reply #3 on: August 08, 2008, 01:46:00 PM »
Make sure the battery is charged. If the battery is super low because you've been driving a lot in traffic, it'll cause the behavior you're seeing. Top off the battery with a charger and try again. The charging system on these bikes is marginal at best.
'75 CB550F
Offline gold72
« Reply #4 on: August 08, 2008, 02:14:36 PM »
my 500 seems to do the same thing
1972 cb500
Offline mystic_1
  • 1970 CB750K
« Reply #5 on: August 08, 2008, 03:56:24 PM »
Tell us more about the bike, is it stock and if not what mods have been made?
mystic_1
- John Augustus Shedd
Offline Pinhead
  • 1979 CB652-ST
« Reply #6 on: August 08, 2008, 04:01:08 PM »
Before you do anything else, follow OldSchool_IsCool's suggestion. That is generally the very first step when suspecting and diagnosing charging problems.
Doug
GM HEI Ignition Conversion
Quote from: TwoTired
:D
Offline feliz
« Reply #7 on: August 08, 2008, 04:12:01 PM »
I have new bikes that do that!! These charging systems are marginal at best. Both my CB750s systems are okay and meet specs but after every ride I put them on the battery tender and it takes 3-5 hours to bring the battery to full charge. Even new(er) bikes I own may take an hour or so but none have ever taken as long as the CBs I currently or have owned. Most of my riding is all or partly in town
though and I assume strickly highway riding would keep the battery charged.
feliz
Current bikes:
05 Ural Patrol
CB750K1, K3, K4
08 Aprilia Shiver
Offline Pinhead
  • 1979 CB652-ST
« Reply #8 on: August 08, 2008, 04:19:09 PM »
I can assure you, that's not normal. My '79 CB650's charging system is just as "marginal" as the 750s and I haven't had to charge my battery since I bought the thing almost 3 years ago. With a little electrical work these problems can be eliminated.
Doug
:D
Offline speedy gonzalais
« Reply #9 on: August 21, 2008, 04:20:41 PM »
Im no expert but what i do know is this is normal in most cases on bikes and cars. The altenator/generator dont produce a full charge when the engine is idle sure it prob wont be the case with brand new altenators but old warn ones it is
82' C90
87' yamaha T80
79' CB125T/CD200 project
82' CB650z
80s kawasaki ae50/150cc project
92' Suzuki GSXR600
80' CB250N
