Author Topic: Weak compression in #2 cylinder  (Read 2306 times)
buffalosabresbrewer
« on: August 08, 2008, 04:11:17 PM »
Im looking at another bike for sale locally. He says it runs but has weak compression in the #2 cylinder.
What might i be looking at here in terms of repair?
Its a 1978 750 super sport. Is the super sport another name for the "F" or am I just missing something? Thanks.
« Last Edit: August 08, 2008, 04:19:50 PM by buffalosabresbrewer »
Re: Weak compression in #2 cylinder
« Reply #1 on: August 08, 2008, 07:17:39 PM »
It's an F bike and probably needs the top end replaced.  Pay accordingly, or keep shopping.
buffalosabresbrewer
« Reply #2 on: August 08, 2008, 08:28:24 PM »
When you say the top end needs to be replaced this involves what exactly?
martino1972
« Reply #3 on: August 08, 2008, 11:06:31 PM »
that involves:
-take engine out frame
-remove cylinder head
-get new valve guides installed
-valves regrinded or replaced
-reassemble
« Reply #4 on: August 09, 2008, 04:27:28 AM »
that involves:
-reassemble
Some will say that is not enough.  That an other-than-short-term-repair requires a K style head and pistons, too.
There has been a a LOT of discussion on his forum about the 77-78 750 F model foibles.
buffalosabresbrewer
« Reply #5 on: August 09, 2008, 07:43:08 PM »
About how much do you think that might cost?
Would these be hard to find?
Offline 750goes
  • it will live
« Reply #6 on: August 10, 2008, 03:03:03 AM »
could also be just a crappy valve adjustment causing the low compression...but worst case scenario is an engine out complete rebuild .... how much money you want to invest or minimise on ??
buffalosabresbrewer
« Reply #7 on: August 10, 2008, 04:17:11 PM »
Well of course I want to minimize the amount of money spend but a grand pretty easily.
