Author Topic: cb550k exhaust question  (Read 1099 times)
Offline NickC
« on: August 08, 2008, 07:43:48 PM »
Alright, been trying to get this bike road worthy. Trying to get it running just right today, and after some time and tinkering, my head was hurting from the exhaust.  Took the tailpipe off to have a look. Is the small piece the baffle, or does a baffle screw to the end of it? The end of it is threaded. Any other tip available than this megaphone looking one?
Thanks!
Nick
Offline Jonesy
  • Shop Rat
Re: cb550k exhaust question
« Reply #1 on: August 08, 2008, 07:45:53 PM »
Are you talking about the "trumpet" shaped early pipes (pre '77), or the megaphone-type found on the '77-'78 550 K's?
Offline Triffecpa
« Reply #2 on: August 08, 2008, 08:11:42 PM »
I don't quite understand your question.  The pipes on the bike in your pics are not stock pipes.  Are your pipes too loud or do they leak (both of which would cause your head to hurt)?
TR
Offline NickC
« Reply #3 on: August 09, 2008, 05:57:52 AM »
The pipes are too loud. I was wondering if the small piece in the picture was the exhaust baffle, or if i needed to find a replacement.
« Reply #4 on: August 09, 2008, 08:50:42 AM »
Who knows as the pipes are an unknown make anything might be going on
Offline WFO
  • Will work for powerbands
« Reply #5 on: August 09, 2008, 10:44:55 AM »
See if you can find some stamping on it to find the maker.
82 cb650 sc nighthawk - 78 kz 650 b
Offline NickC
« Reply #6 on: August 09, 2008, 02:56:42 PM »
Can't find any markings. After further inspection, it is missing another piece. Towards the end of the pipe, facing the wheel, is a small hole, most likely for a screw.
Now I just have to find out what exhaust it is..... :-X
Offline Hush
« Reply #7 on: August 09, 2008, 03:41:51 PM »
What the heck is he running there, can't tell if it's a 4 into 1 or a two into 1???
First look I thought he had twisted a set of CB650 pipes across the front of the head but looks like the inner rusty one joins the chrome one just under the motor.
Offline NickC
« Reply #8 on: August 09, 2008, 03:48:10 PM »
4 into 2
1 and 4 joined, and 2-3
Offline hymodyne
« Reply #9 on: August 09, 2008, 04:36:37 PM »
someone jammed a lawnmower silencer in the pipe. the threaded portion screws into the cylinder head on a briggs and stratton or Tecumseh engine.
hym
Offline WFO
« Reply #10 on: August 09, 2008, 04:46:53 PM »
hym
No doubt a top secret acme speed mod from wylie coyote suuuuuper genius.
« Last Edit: August 09, 2008, 04:49:03 PM by WFO »
Offline NickC
« Reply #11 on: August 09, 2008, 09:31:47 PM »
Hahah another shady item found on my $300 bike!!
So, now that I know that, anyone recommend universal silencers that might work?
