Author Topic: BROKE MY EFFING TACH...ANY TIPS?  (Read 1656 times)
Offline chippyfive50
  • NO PEE ON TEPEE
    • thesweetimpala
« on: August 09, 2008, 05:35:33 PM »
I am restoring my K4 750, it is going well but slow, I decide to reface my gauges.
I gently pry the ring off and separate the gauge with swiss-like precision in about 5 min.
I then proceed to gently pull up on the needle expecting it to slide off the driveshaft... (I did this on my 550 with no problem).
welp..it came off with a snap. busted. EFF.
Does anyone have any tips for the needle removal??? should it just pull off??   I was hoping to do my speedo too..
SOHC Member#4000
71' 500K0 #1021237--E1108327
78' 550
72' 750K2(sold to "Craig")
74' 750K4 #2306334--E2303422
73' CL175
http://gallery.sohc4.net/main.php?g2_itemId=14013
Offline UnCrash
  • Pass
    • My Blog
Re: BROKE MY EFFING TACH...ANY TIPS?
« Reply #1 on: August 09, 2008, 06:20:37 PM »
Doh! I hate when that happens.
I have a spare 74 tach in the garage.
PM me if you need it...  maybe we could swap for something.
Best of luck with your rebuild.  I checked out your photo gallery and gotta say your 550 looks killer with the whitewalls.
Offline bradweingartner
  • 74 CB 550 x2
« Reply #2 on: August 09, 2008, 07:14:37 PM »
I would say you should send that broken unit to me, since I've been looking for a broken gauge housing!
Oh, and I'm sorry for your loss  :-[
Offline Johnie
« Reply #3 on: August 09, 2008, 07:59:49 PM »
I use the 2 spoon trick that I heard here.  Hold the 2 spoons face up with an edge of each spoon under the needle.  Slowly pry up on the needle evenly with both spoons and it will pop right off.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
  • NO PEE ON TEPEE
    • thesweetimpala
« Reply #4 on: August 09, 2008, 08:04:56 PM »
Perhaps i could do that...
I have an aftermarket model,  and a spare off of a 72.  Im afraid if I try again I will kill another one...
SPOON TRICK EH......
SOHC Member#4000
78' 550
73' CL175
Offline CBGhia
« Reply #5 on: August 09, 2008, 08:33:32 PM »
I used the spoon trick as well.  Worked like a champ.
Offline Raul CB750K1
« Reply #6 on: August 10, 2008, 06:58:30 AM »
Damn! I should have known about the spoon trick. I bought a set of instruments to replace the cover, and as the faces looked good, I tried to remove the needle to change the faces too. I gave up when I understood I could ruin the original faces, that were not that bad.
