Author Topic: Head gasket replacement on CB350 F  (Read 4260 times)
Offline johnzmg
« on: August 10, 2008, 07:38:03 AM »
Hi All,
I'm about to replace the head gasket on my 72 CB350 four for the second time. The result of my first effort was an oil leak as bad or worse than when I started. The first time I used a off brand gasket set this time I have Honda parts. I'm looking for advice... do you use sealant on the "o-ring" seals the seal the oil passages? How about on the head gasket? What do you use in these locations?
Thanks!
John
Offline malcolmgb
  • What am I not? an
  • The BEST 400 four by far
    • malcnet
Re: Head gasket replacement on CB350 F
« Reply #1 on: August 10, 2008, 12:18:59 PM »
I never use anything on head gaskets, perhaps a light smear of light grease/vaseline on o-ring to allow it to align itself. Make sure head and barrel mating surfaces are perfectly clean with acetone and since it is second time is head warped it may need skimming. Always use a torque wrench to tighten down and use correct sequence of tightening head nuts.
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
Offline Sporkfly
  • The frosty rider
  • Mmm, Guinness
« Reply #2 on: August 10, 2008, 12:55:11 PM »
I used a copper spray adhesive on mine. It wasn't necessary, but I didn't see how it would hurt.
1977 CB550K
1979 CX500
1976 Suzuki GT500 Titan
Offline hoodellyhoo
  • CB350F
« Reply #3 on: August 10, 2008, 01:01:30 PM »
Not that I'm an expert, but did you re-torque the head after running a bit on the last head gasket? There was a recent thread where someone had a new head gasket leaking but hadn't re-torqued the head after putting on a few miles.
Offline johnzmg
« Reply #4 on: August 11, 2008, 02:27:38 PM »
Thanks all. No, I never got to re-torque the head after replacing the gasket. It was leaking oil as soon as it warmed up. So, clearly I did not get one of the seals seated correctly or the seal is not to spec (it was a non-Honda gasket kit). I checked the cylinder and head for flatness but did not use gasket sealer on the seals, just grease. I thought that might be the problem. I have Honda parts now and plan to revisit the job in couple of days. Thanks again. John
