Author Topic: rear tire leaning  (Read 2377 times)
ratfink56
rear tire leaning
« on: August 10, 2008, 02:31:03 PM »
I pulled the rear fender off my 77 750 and noticed that the tire leans to the right. There is almost a 1/2" diffrence in the shock mount measurement from one side to the other with the shocks removed. I don't see any damage and the swingarm and wheel are not sloppy. Any ideas?
Offline droopy
Re: rear tire leaning
« Reply #1 on: August 10, 2008, 02:33:41 PM »
frame / swingarm bent I'm betting swingarm :( :'(
2007 lifan 200cc sport ohc thumper
ratfink56
« Reply #2 on: August 10, 2008, 04:49:55 PM »
guess I'll pull it and have a look see. damn thing is so stout I can't imagine it's bent. However the bike does have an 18" rear wheel and everything I've read says it should be 17. Thanks for the input.
Offline eurban
« Reply #3 on: August 10, 2008, 05:21:21 PM »
You could have issues as I don't completely understand your explanation, but . . . If you look closely (and measure carefully) you will find that your upper shock mounts stick out more from the frame rail on the left side than on the right side of the bike.  You also should find that the swing arm forks and the attached lower shock mounts are shifted to the left the same amount, lining up with the top shock mounts.    You should also notice that the rear wheel is shifted to the right in the swingarm the same amount that the swingarm is shifted to the left.  Guess what?  This puts the rear wheel "exactly" back on the centerline of the bike as referenced  off of the frame rails.  Honda built it this way (at least the late bikes) but I can't say for sure why.  Probably allowed for proper chain clearance.  Read this thread if you like, where I started off worrying that my rear wheel wasn't installed correctly.  After I spent a good amount of time looking at everything I decided it was as intended.  Hopefully your situation is similar . . .  http://forums.sohc4.net/index.php?topic=7764.15
You really should post this in the SOHC4 bikes section as it gets more readership.  The project shop is supposed to be for posts showing off and discussing bike builds.
« Last Edit: August 10, 2008, 05:31:40 PM by eurban »
ratfink56
« Reply #4 on: August 10, 2008, 05:46:45 PM »
the wheel is not offset but leaning to the right at the top. perhaps the moderator will move the thread to the proper area for me. thanks for your input.
ratfink56
« Reply #5 on: August 11, 2008, 06:16:02 PM »
pulled the swingarm and it is tweaked hard. no signs of road rash or damage but the bike was in some kind of incident. in need of a swingarm...
Offline eurban
« Last Edit: August 12, 2008, 11:51:27 AM by eurban »
ratfink56
« Reply #7 on: August 13, 2008, 04:14:33 AM »
eurban, thanks for the hook up on the swingarm.
