Author Topic: 1973 CB350F "Freakshow Build" completed! Stay tuned for updates...  (Read 136307 times)
Offline RM81
  • 4 out of 3 people have a problem with fractions
Re: 1973 CB350F restoration project started today. Should be a freakshow.
« Reply #100 on: August 20, 2008, 04:58:20 PM »
Tim,
I'm glad you're asking all the same questions I'm sure I'll have when I start my rebuild.  Lots of good info here coming from the others and I'll be reading back through it all when I'm ready to start.
Offline scunny
  • don't call me expert
« Reply #101 on: August 20, 2008, 05:08:58 PM »
those rings should be free to turn Tim.
doesn't sound good about those scratches tho, I think you're up for new pistons(and wrist clips)
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline kghost
« Reply #102 on: August 20, 2008, 05:11:03 PM »
Yeah Tim....the rings get tighter when shoved in the cylinder Bore.
Stranger in a strange land
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
« Reply #103 on: August 20, 2008, 05:46:55 PM »
Matt (or anyone) remember those oiler manifolds on the head that we were talking about?  Since they just sit down in those holes, (and could come off and be lost or damaged if someone at the machine shop was careless...  should I just pull those out and bag 'em here at home first?  (my gut says yes)
Yup. pull them out and bag um!.....dowels too!
Most machine shops are trustworthy but they wont need them so dont send them.
 Matt.
Gallery at:
Offline Tim in Ohio
  • So I got that goin' for me, which is nice.
« Reply #104 on: August 20, 2008, 06:03:35 PM »
Matt,
What are the dowels?  (not kidding).   ::)
1973 Honda CB350  Four
Check out my CB350F resto project...  watch a complete moron build a bike in front of your very eyes!: http://forums.sohc4.net/index.php?topic=38903.0
« Reply #105 on: August 20, 2008, 06:55:48 PM »
They did.  I have a new top end gasket set on the way though...  good idea, yes?
i wasn't implying that you should reuse them , just that there removal will be easier because they are in one piece
dowels are the little metal slugs that aline the cases , spray them with PB blaster or WD-40 and let it soak for awhile , pull them out with a pair of pliers with a rag wrapped around them (wrapped around the pliers not the dowels ;) ;D)    you don't want to score the dowels up, if you do you'll have to get the burr off with sandpaper,file,dremel or the like
EDIT: after looking at your pics, i see that you have the hollow dowels not the slug type , little sleeve that valve cover mount screws go through  ,on the top corners of the head, ... and it looks like your missing one
« Last Edit: August 20, 2008, 08:41:26 PM by spikeybike »
Offline rachet
  • '77 CB750 F2
« Reply #106 on: August 20, 2008, 08:26:33 PM »
It's threads like this that make this forum Kick-ass!  Great build Tim!  It's encouraging to see you dive head first into this project.  Thank you! and thank you for asking all the questions, It's stuff I need to know as well.
Keep up the great work!
Rachet~
But I need Tacos!  I need them or I will explode!
Offline Tim in Ohio
« Reply #107 on: August 20, 2008, 09:11:59 PM »
Rachet,
Thanks for the positive feedback.  Like I said at the beginning, I'm fed up with being a wanna-be.  So, I figured diving in head first was the only way to learn this stuff.  I agree about this forum kicking ass.  The guys that have generously shared their time, knowledge and encouragement throughout this thread are my heros!  Seriously, I never would have had the courage to disassemble this engine without them.  Aw shucks, enough of this mushy stuff  :'(
I am loving every minute of this project and I will feel really proud when I get her running the way she should.  I hope all of you guys will get a kick out of it too.  Thanks for checking in Rachet.    :)
Tim
« Reply #108 on: August 20, 2008, 09:18:16 PM »
group hug!!  hey, who grabbed my ass
martino1972
« Reply #109 on: August 20, 2008, 09:52:05 PM »
wasen't me... ;D ;D ;D
make sure you take the pistons along to the shop,scratch numbers in the top of em so you know out of what cylinder they came....
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
« Reply #110 on: August 21, 2008, 07:32:45 AM »
That's a good point martino, very important not to mix up which piston goes in which cylinder. In fact, I would have four seperate large ziploc bags and for each piston and keep the wrist pins, clips, rings, and pistons together for each piston.
Oh, and about those piston clips.... you're gonna have to remove at least one of those little clips to take the wrist pin out of the piston so that it will come off of the connecting rod. They're tricky little buggers to get off and sometimes leave the piston at high velocity.......so where safety glasses  ;)
Also, you'll want to place a rag under the piston and around the connecting rod to prevent the piston clip or any other parts from falling into the engine.
Added a pic here for ya:.......#10 are dowels and #11 are piston clips, #8 are wrist pins
 Matt.
Gallery at:
Offline Tim in Ohio
« Reply #111 on: August 21, 2008, 07:38:23 AM »
Thanks Matt.  That should give me everything I need to know.
Kghost- I received the intake boot.  It is exactly what I needed.  Thanks!
« Reply #112 on: August 21, 2008, 07:40:26 AM »
VERY important , don't skip this part, if you drop a clip in the motor , it's bad news.  you'll have to open the bottom end and still might not find it .       ( i speak this from experience, it's no fun  ::))
« Reply #113 on: August 21, 2008, 07:58:45 AM »
Besides stuffing the rag, etc. I stick a fat phillips screwdriver or punch in the pin hole so when the clip pops out it can't go anywhere.
Offline kghost
« Reply #114 on: August 21, 2008, 09:13:18 AM »
Kewl....
Your making hella good progress Tim.
Keep up the good work
Offline Tim in Ohio
« Reply #115 on: August 21, 2008, 01:41:36 PM »
Hey fellahs.  Check it out.  Pistons came of with out even offering to put up a struggle!
(The rags blocking the holes were a lifesaver though.  Great tip.)
Ready to take to the machine shop for measurements and diagnosis I reckon:
Now about those pistons.  I did what Martino (or was it Spikey) said and I scratched the 1 - 4 into the carbon on top of the pistons.  I did what Matt said and created 4 separate bags, One for each piston, it's wrist pin, and clip.   Two things about that:
1)  Will the machine shop need the wrist pins and clips as part of what they will be doing?  I'm thinking No.  So, should those bags stay safely at home with me where I can be sure they won't get mixed up or lost?  Or do I indeed need to hand over the four bags, piston, pin & clip 1 -4 to the shop?
2) As I said, I scratched the piston numbers into the carbon on top of the pistons.  Is there any danger of the friendly machine shop cleaning that carbon off for me and thereby causing me to lose track of which goes to chich cylinder?
Offline scunny
« Reply #116 on: August 21, 2008, 01:48:06 PM »
machine shop wont need the pins and clips. mark your pistons underneath as well and mention it to them
            VTR1000F3
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
« Reply #117 on: August 21, 2008, 01:51:27 PM »
Good work Tim  8) You're going to give kghost a run for fastest restoration  :D
They shouldn't need the pins or clips but will need the rings so keep the pins and clip in the 'stay home' parts bags.
the machine shop will clean the carbon off those pistons for sure. What you can ask them to do is mark the pistons for you, or at least three of them with either punch marks (two dots for #2, three dots for #3 and so on) or some machinists actually have number punches for marking pistons.
This is standard procedure.... my pistons have the numbers permenently marked on the domes now from my rebuild.
 Matt.
Gallery at:
Offline Tim in Ohio
« Reply #118 on: August 21, 2008, 02:04:41 PM »
Guys,
I found a motorcyle machine shop not too far away, who will measure the valve tolerances, and the cylinders, pistons, etc.  for around $35.  I thought that sounded pretty reasonable.  I will be taking them in to him tomorrow.
Now, About thos buggered threads on spark plug hole number 1...   Maybe now would be the time to try threading a spark plug in from the other side and see if it works.  That way, if i totally screw the pooch, I can have the machine shop guy fix it while he has it?
Now...  This has been a real brain twister for me...  When I screw in the plug from the other side...  do i turn it clockwise, as I would from the normal side, or do I have to turn it counter-clockwise, because I am coming up from the other end???  Prolly a real dumb question, but...  you know...  :-[
Offline Tim in Ohio
« Reply #119 on: August 21, 2008, 02:11:04 PM »
I did a little sketch, and I THINK the answer is, thread it in clock-wise...  just as I would from the other side.  Right? 8)
Offline kghost
« Reply #120 on: August 21, 2008, 02:21:29 PM »
Yup.
Offline Tim in Ohio
« Reply #121 on: August 21, 2008, 03:35:59 PM »
OK guys, no need to twiddle our thumbs while we await the results from the machine shop.  Let's press on.   Take a look at this sorry excuse for a muffler.  Right now is NOT the time for me to be paying hundreds of dollars for a nice exhaust system,  what are we gonna do?
Closer:
Scunny, Martino...  I notice you guys have some of that wrap stuff on your exhaust.  Would that be the ticket in my situation?
Offline scunny
« Reply #122 on: August 21, 2008, 03:39:55 PM »
since you don't want to spend money on it, wrap it then move on. it will look like #$%*e but you can always revisit it when funds allow
            VTR1000F3
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
Offline kghost
« Reply #123 on: August 21, 2008, 03:57:25 PM »
I dunno...if its not a 4-4 system....mufflers are pretty cheap.
Offline Artfrombama
  • Card-carrying, board certified
  • CB750 K2
« Reply #124 on: August 21, 2008, 04:04:19 PM »
Fire it up and tune it in with the present system, then buy a nice used or aftermarket.
Easy enough to change at a later date.
Halfassed machinist
Tinkerer/goof-off/Mr. Fix-it
CB750-2011594 Sunrise Flake Orange
CB750E2441103
