Author Topic: Cracked triple tree- how safe?  (Read 1651 times)
Offline Odge
« on: August 10, 2008, 11:09:08 PM »
I am in the process of trying to install a wixom fairing and I noticed that the top left triple clamp is cracked all the way through. I have lined up a new top triple clamp but it will take a few days to arrive. :P How bad an idea is it to keep riding until I can fix it? Also are there any special difficulties in replacing the top triple tree?
Offline rhinoracer
Re: Cracked triple tree- how safe?
« Reply #1 on: August 10, 2008, 11:13:02 PM »
If it wasn't a bad idea you wouldn't be having second thoughts now, would you ;)
Baja native.
Offline Odge
« Reply #2 on: August 10, 2008, 11:18:20 PM »
Guess not-I just can't stand the idea of commuting in my car for a week.
Offline Steve F
« Reply #3 on: August 11, 2008, 06:36:33 AM »
Imagine laying in a hospital bed for 10 times that...  >:(
Offline Johnie
« Reply #4 on: August 11, 2008, 07:31:29 AM »
I agree with Rhino and Steve...park it.  You are placing unexpected forces on that tree and expecting the other areas to pick up the slack.  The tree was designed to withstand the forces in a triple uniform pattern. You may not have a problem but why chance it.  It you do experience a failure it will not be like spilling milk on the table but could be your life.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #5 on: August 11, 2008, 08:37:53 AM »
I take it you mean where it clamps to the top of the fork tube, in which case park it ALSO look at the parts fiche as there ought to be a special washer in the gap on the clamp bolt to stop the bolt being over tightened and breaking the clamp
Offline Odge
« Reply #6 on: August 11, 2008, 08:41:17 AM »
Sound advice- I'll drive the car for the time being. Anyone know what is involved in removing the top triple tree- Is it difficult?
Offline Johnie
« Reply #7 on: August 11, 2008, 11:20:49 AM »
Pretty easy job and you can even stand up doing it.  May want to pack the bearings as long as you have it out.  I still have ball bearings on mine and they were a bit dry.  On my KO I was able to pack the top and bottom without removing the forks and using a small jack to raise the neck a bit to get at the lower bearings.  The biggest pain is getting the handle bars out of the way with all the cables attached to it.  And like Bryan said, watch for the special washer with the cut-away side that goes in the clamp area on top.
« Last Edit: August 11, 2008, 11:24:27 AM by Johnie »
Oshkosh, WI  USA
Offline Odge
« Reply #8 on: August 11, 2008, 06:02:49 PM »
Thanks for the advice about replacing the triple tree. I know that I have never greased the bearings, and who knows how long it was before that, so I better have a look. There are some very helpful people on this forum!
Offline WFO
  • Will work for powerbands
« Reply #9 on: August 11, 2008, 06:10:32 PM »
There ya go no sense killing yourself if you don't have too also major rep for the sleestack avatar.
82 cb650 sc nighthawk - 78 kz 650 b
Offline fmctm1sw
« Reply #10 on: August 11, 2008, 06:44:21 PM »
A cracked top clamp is the perfect gift for the ex-wife or in laws...
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline Odge
« Reply #11 on: August 14, 2008, 04:48:09 PM »
I'll remember the gift idea. ;D Also points for recognizing a sleestack!
