Since buying this bike 6 weeks ago I've tried to several times to re-align pipe from No. 2 cylinder because it has a fairly deep score in it from the spring on the side stand rubbing it every time it goes up or down. It's going to foreshorten the life span of this pipe a lot.
When I've attempted to re-align, I've tried positioning it and first tightening the head clamp or the mounting bracket on the passenger pedal mount, but it always goes back to the same position. There was also a 3/4" spacer on the pedal mount bracket that didn't look stock and I tried removing it to see if that helped. Made little, if any difference.
I'm assuming these pipes are original. Is there a trick here? What could be causing the misalignment? The geometry of this keeps me scratching my head.
Thanks for your suggestions.
