Author Topic: Hotter running spark plugs for cb550 f2 1977  (Read 1560 times)
Paul P.
« on: September 07, 2005, 12:18:05 PM »
Hi my bike is runing to rich and I would like to try and run a hotter plug to see if it makes a diffrence
I am using   NGK DR7ES could any one tell me the number  of a plug that would run hotter :-\
it does not mater what make and may be you could let me know of a supplier I am in the UK MIDDX .
Re: Hotter running spark plugs for cb550 f2 1977
« Reply #1 on: September 07, 2005, 12:51:15 PM »
Your spark will be hotter if you simply change to non-resistor plugs.
With NGK plugs, the lower the number the Hotter the heat range.  Try to get them without the R in the number.
D7EA (or S) is correct for your bike.
D6EA would be hotter heat range.  This would suck less heat out of the combustion area.
