Author Topic: 750k cylinder dowel. Unavailable?  (Read 1498 times)
Offline brazwell
  • Honey, everytime I ride my bike, god saves a baby turtle.
« on: August 11, 2008, 06:41:21 PM »
So I ordered a cylinder dowl my local shop last week along with some other neccesities, today I receive a phone cal saying they were unavailable. Does anybody know of a source for replacement, No luck online. Any help would be greatly appreciated.
« Last Edit: August 11, 2008, 07:14:45 PM by brazwell »
73' CB750
49' Panhead El
Unicycle (w/ flat tire)
Offline shoemanII
  • just another bike nut
Re: 750k cylinder dowel. Unavailable?
« Reply #1 on: August 11, 2008, 07:33:23 PM »
i have (one) 12mm x 14mm and (three) 12mm x 18mm steel dowels laying around.  will cost you .42
bobp
'96 ducati carb'd 900ss/cr
'72 dt2
'77cb550k frankenberry:  '77cb550k frame, '78cb550k engine, '78cb550f tank, unknown front-end
Offline brazwell
« Reply #2 on: August 11, 2008, 07:56:02 PM »
Need to measure tommorow and figure out what size they are, believe they are 14mm. Thanks for the offer will let you know once Im able to measure the one that I do have.
73' CB750
49' Panhead El
Offline tomkimberly
« Reply #3 on: August 11, 2008, 09:26:08 PM »
If you know the size order from McMaster-Carr or any other good hardware supply store.
Tom
« Reply #4 on: August 11, 2008, 09:29:22 PM »
I sorta dont think they carry the Honda type dowel..s..
Offline tomkimberly
« Reply #5 on: August 11, 2008, 09:33:26 PM »
My bad, I keep forgetting most people call guide pins dowel pins.
Tom
Offline jtb
  • An unlikely
« Reply #6 on: August 12, 2008, 05:46:26 PM »
I've probably got a couple laying around, too.  Let me know if you need one.
1977 CB750F
1985 V65 Sabre
Offline brazwell
« Reply #7 on: August 12, 2008, 08:05:41 PM »
Thank you all for your responses, will post the size tommorow. Ive now giving up hope of finding new dowels. Havent even found used ones online!
73' CB750
49' Panhead El
Offline KB02
« Reply #8 on: August 14, 2008, 04:43:09 AM »
I thought I saw a post on here a while ago about replacing the guide pins and someone used the pins out of another bike. I think it was an Interceptor. The pins were just a little too long, so they had to cut them down.
I'll search and see if I can find that post. I'll be needing some too, for my build as I get ready to put the engine back together (Finally!!!)
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline Kevin D
  • SE Michigan
« Reply #9 on: August 14, 2008, 06:08:03 AM »
 I used a 94301-12200 (12x20mm). I found it on a ST1300 fiche.
http://forums.sohc4.net/index.php?topic=34148.msg352569#msg352569
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline mystic_1
  • 1970 CB750K
« Reply #10 on: August 14, 2008, 09:45:29 AM »
Thanks KevinD, I remembered posting in that thread but had not had the time to dig it up again :)
BTW, for anyone who doesn't already know this, the second half of the part number for honda knock pins is based on the size, so for example
94301-12220 = 12x22
94301-12180 = 12x18
94301-08140 = 8x14
So, you can just 'make up' your part numbers and see if that size is available.  Getting a shorter size by one or two increments should be ok in most cases, so long as the diameter is correct.
mystic_1
- John Augustus Shedd
