Author Topic: Fuel Petcock Lever Leak CB650  (Read 704 times)
evitek
« on: August 11, 2008, 08:01:11 PM »
It leaks when I rotate the lever from off to on for a few drops and stops.  It sounds like I need a new rubber gasket just behind the lever.  Anyone have luck buying one for a 82 CB650 [riveted plate design]?  I haven't taken it apart but I would like to get the part before I do the disassembly.  If the part is not available, any suggestions for rubber gasket restoration?
Offline tomkimberly
Re: Fuel Petcock Lever Leak CB650
« Reply #1 on: August 11, 2008, 09:29:57 PM »
Unless you are really low on cash, I would just purchase a new one from Honda or a aftermarket one from Z1 Enterprises.
Tom
