Author Topic: Speedometer/Tachometer Lense Cleaning  (Read 5011 times)
cjackel
« on: March 28, 2005, 10:10:24 AM »
Here's the issue:
It looks like the original owner cleaned the inside of the speedo and tach lenses, as
I can see smear marks and wiping streaks, when the light hits them at certain angles.
How does one remove these to clean without dinging up the cases?
 I looked at mine
and there's no evidence that they were pried apart or opened.
The article posted on the web describes using a screwdriver, but it seems like it
would leave evidence of opening. My speedo and tach look brand-new except for
the streaks and smears inside the lenses.
Re: Speedometer/Tachometer Lense Cleaning
« Reply #1 on: March 28, 2005, 02:16:07 PM »
Those smears are normal. Apparently as the guages age it becomes more noticable. It os probably because of sun exposure, hot/cold cycling, condensation etc. Some are worse than others too.
Offline fergie
« Reply #2 on: March 28, 2005, 04:43:39 PM »
Ive got the same smears on my 78 550 and I know mine have never been apart. cheers Fergie
The most interesting man in the world
Offline cben750f0
cb750_chris
« Reply #4 on: April 11, 2005, 06:19:42 AM »
It probably involves taking the instruments out from the back.  I intend on doing this by removing the adhesive holding them into the body.  It seems similar to liquid nails to me.  This may leave some evidence of tampering though so I am only doing this because my guage bodys are shot.  Not just to clean up the lense or instument face.
cb750_chris
« Reply #5 on: April 11, 2005, 08:54:32 PM »
P.S.  Don't use glass cleaner on plastic lenses.  You know all those plastice window jeeps and sidekicks you see with fogy windows.   Ammonia doesn't like plastic.   You should only use water + maybee some soap to clean plastic.
Offline 750deepsouth
« Reply #6 on: April 12, 2005, 03:57:13 AM »
I can endorse the ebay item mention by chen
Offline cben750f0
« Reply #7 on: April 12, 2005, 04:16:19 AM »
CBen mate... CBEN!!!... hahaha... cool....
« Reply #8 on: April 14, 2005, 03:25:46 AM »
Cben - oppps - sorry  :)
Offline kghost
« Reply #9 on: April 14, 2005, 07:19:15 AM »
You can take them apart by spreading the band (chrome) that holds the gauge together. I start on the back as small imperfections are less noticable when reassembled. A second set of hands is really helpful when rounding the strip back on the gauge on reassembly. Ditto on the use of PLASTIC cleaner, ammonia bad. Heres a picture of some I made and a face sticker I made up.
Stranger in a strange land
eldar
« Reply #10 on: April 14, 2005, 03:41:14 PM »
Well I cant find it right now but I am sure someone else knows the site. It was in the greenspun forums, It was a socal site that had instructions on how to take apart the housings to clean and lube them.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #11 on: April 14, 2005, 07:44:43 PM »
I think this is the link you are referring to;
http://www.salocal.com/sohc/tech/speedo/spedo1.htm
