Author Topic: Engine re-assembly question  (Read 1430 times)
Offline ZanVooden
  • I don't need no stinkin' title
  • This was suppose to be a quick one month job...
« on: August 14, 2008, 09:17:33 AM »
Alright so I'm getting ready to re-assemble my 750K8 engine here in the next couple of days (depending on when I get my last freaking valve spring, that I've been waiting on for 2 months now), and I was wondering whether or not I should use assembly lube on the gaskets as the engine goes back together, or just put them on clean and dry.
Dave
Offline mystic_1
  • 1970 CB750K
Re: Engine re-assembly question
« Reply #1 on: August 14, 2008, 09:52:16 AM »
Just put them on clean and dry.
mystic_1
- John Augustus Shedd
Offline mrosso
  • The before picture.
« Reply #2 on: August 14, 2008, 09:55:06 AM »
Speaking of assembly lube... Is it recommended to put moly assembly grease on certain parts like bearing shells, gears, etc. when assembling a CB750 motor? If so, which parts should you apply and which should you avoid.
Offline bunghole
« Reply #3 on: August 14, 2008, 10:45:28 AM »
Hmmm.  I kind assumed you could slather it all over everything that would normally be covered in oil, but I'd be interested to hear if that isn't the case...
'05 HD FLSTCI (Heritage)
'06 Suzuki DRZ400S
'08 Honda VFR800
'77 Honda CB750K
Offline LoopsAndLogic
  • Dang IT!!!
« Reply #4 on: August 14, 2008, 11:17:15 AM »
I made the rookie mistake of using Molly lube on my cams on a Interceptor.
The molly lube they use on cars, contains graphite which in turn ruins the clutches. I'm still waiting for them to slip on me.....
 It's only been 40miles. $300 clutches here I come.
But when installing new parts such as cams and bearings its highly recommend that you use MOTORCYCLE specific assembly lube.
 When you just put normal motor oil on them, in just a few days, the oil runs right off.....just leaving a very thin layer of oil.
Now if you were to be putting the engine together in one or two days and starting her up, then by all means, use some good 10w-40 oil.
But learn from my mistake. ::) ::)
Best of luck
LL
My rides:
75' 76' Honda CB400F Super Sports
86' Honda XR600R for Street Madness
84' Honda Interceptor VF500
Past Rides:
80' Honda CX500C Fully Dressed
81' Honda CB650C very nice!
83' Kawasaki KZ550 A3
78' Hondamatic 400 Hawk
80' 81' 82' Honda GL500 Silverwing Insterstate
Offline Sporkfly
  • The frosty rider
  • Mmm, Guinness
« Reply #5 on: August 14, 2008, 11:23:30 AM »
I used the really thick clear STP oil additive (I don't imagine small amounts will hurt the clutch) as it won't run off. Lube the pistons/cylinders and cam lobes. If you are doing a bottom end job with the crankshaft and such, lubricate the bearings. If you don't you could seize things up. Kick it over without gas in the bowls a good number of times to circulate your oil.
When I started it up I had no smoke. I really think kicking it over before starting it to circulate oil and scrape the cylinders helped a lot with this.
EDIT: I should say a VERY thin layer was used, not gobbing it on or anything.
« Last Edit: August 14, 2008, 01:04:31 PM by Sporkfly »
1977 CB550K
1979 CX500
1976 Suzuki GT500 Titan
« Reply #6 on: August 14, 2008, 11:45:30 AM »
 I use Red Line assembly lube. Never any problems.
Offline bunghole
« Reply #7 on: August 14, 2008, 12:37:51 PM »
I'm using Redline too.
I've heard some people recommend lubing the cylinders and others recommend not.
Thoughts?
'06 Suzuki DRZ400S
'08 Honda VFR800
'77 Honda CB750K
« Reply #8 on: August 14, 2008, 12:41:21 PM »
Thoughts?
I very, very lightly coat the cylinders with motor oil (more to stop rusting than anything else). The cylinder walls are basically dry.
Offline Bido
« Reply #9 on: August 14, 2008, 03:27:48 PM »
Clean and dry new gaskets be very sure mating surfaces are clean.
Good Luck
Bido
1978 CB750 Supersport F3
1981 CB750 K
Offline rbmgf7
  • 2>4
« Reply #10 on: August 14, 2008, 03:42:41 PM »
Thoughts?
the guy at total seal gave me some assembly oil for the rings and piston skirts. it's has consistency of light oil. i usually rub oil on the walls and right before start up i drop in about a teaspoon full so i know the walls have some coating. just makes start up a little smokey
