Author Topic: How to connect cb750k Oil tank?  (Read 1133 times)
Offline Marco83
    • *My PhoTo AlbUm*
« on: August 20, 2008, 01:54:05 AM »
Hi guys,
on my cb750k, there is 2 part of the oil tank i do not know connect to where.
i left it without connect and engine oil will leak from there when the bike run.
do anyone know unknow 1 and unknow 2 on the photo connect to where?
thank for looking.
Marco
Offline nippon
    • Classic Cycle City
Re: How to connect cb750k Oil tank?
« Reply #1 on: August 20, 2008, 04:05:15 AM »
nippon
« Reply #2 on: August 20, 2008, 04:44:38 AM »
Keep in mind Marco that when connecting the lower nipple on the oil tank to the crankcase (lower crankcase just below the tab where the carb overflow tubes go through) that if you have an early K oil tank and are trying to fit it to a F engine (I seem to recall you were going to do this) that the nipple on the crankcase may be larger diameter than the oil tank.
I hope that makes sense!
cheers
Andy
rhos1355
« Reply #3 on: August 20, 2008, 05:53:36 AM »
Marco, here's a couple of pics of my oil tank when I was doing the stripdown. The bike is a 750 K2 by the way. I hope they help.
It might be a little obscured but if I remember correctly the thicker rubber tube just hangs thru the frame emptying any overflow
The smaller rubber tube seems to be connected to the back of the gearbox case.
« Last Edit: August 20, 2008, 06:01:37 AM by rhos1355 »
Offline Marco83
    • *My PhoTo AlbUm*
« Reply #4 on: August 20, 2008, 08:16:40 PM »
guys, thank for the reply. i will check it out later.
thank you so much
Marco
