Author Topic: universal bulb replacement numbers  (Read 3483 times)
Offline starkmojo
  • Yes I am tall...
  • Wow that bike is Orange, but I kinda like it.
« on: August 20, 2008, 11:42:27 AM »
Sorry I did look.
I am thinking about replacing my lights with LEDs- but I cannot find the bulb #s. i am doing some research and looking online for information but cannot seem to find what i need.
anyone lend a hand?
specifically looking for front running light turn signal bulbs and rear signal bulbs
thanks
twoold to give up
twotired to care..
Offline eurban
Re: universal bulb replacement numbers
« Reply #1 on: August 21, 2008, 04:54:14 PM »
Ok on principle, I'm not going to answer your question.  Why?  Cause I can't see the point in having a "Tricks and Tips" section where the poster is asking a question.  The only reason I can see to have a separate section here is if the poster is offering a trick or a tip that they have come up with.  Otherwise, why have a separate section?  Put your question(assuming it is about a SOHC4) in the "SOHC4 bikes" section where there is a much larger readership . . . . .
Ok I lied, what bike are you asking about?? Somehow I remember you having a 77 or 78 750??  If so, download the factory manual here and it should have all the specs you need.
http://www.mediafire.com/?5ttzdg9yyuz
If its not a 77/78 go to the FAQ section and look under "manual FAQs" and hopefully find the manual for your bike . . . .
Offline super pasty white guy
  • I'm not really a
  • 1976 750 F
« Reply #2 on: August 21, 2008, 05:10:29 PM »
and.. (my opinion) go to www.superbrightleds.com and buy the brightest lumen leds available.  you'll be done looking for bulbs for the life of the bike.  Actually, you can look at the pictures there and figure out what you need.
spwg
comp
« Reply #3 on: August 27, 2008, 09:55:08 AM »
spwg
thanks for the link
