Author Topic: Cb550k older fuel vale with round bowl.....  (Read 858 times)
Offline L.A. Nomad........
  • 1976 CB550 K
« on: August 20, 2008, 12:13:39 PM »
I have a older gas tank on my CB550K, the kind with a Round fuel bowl. The fuel valve is leaky, are the o-rings just bad? Could I use common size o-rings to fix it? Or do I have to order a special o-ring set????
I ask this before, I drain my tank and pull the tank off!
Thanx guys!
I am a fuel-injected suicide machine! I am a rocker! I am a roller! [I’m an outta controller] I am the Chosen One! The Mighty and the Vengeance! Sent down  to strike the unroadworthy! I'm hotter  than a rolling dice!
Offline pablo78cb550
  • mmmph.
Re: Cb550k older fuel vale with round bowl.....
« Reply #1 on: August 20, 2008, 01:50:37 PM »
hey eddie, i've used common o-rings and haven't had any problems yet.
Bikes in hand:
1977 Yamaha XS650
1978 Yamaha SR500 #119!
1978 Yamaha XS400
1978 Honda CB550K
1965 Ducati Monza 250
Sold off:
1992 Yamaha FZR600
1981 Yamaha Seca 550
Offline mystic_1
  • 1970 CB750K
« Reply #2 on: August 20, 2008, 07:59:01 PM »
Depends on where the leak is.  If it's leaking from the bowl or from where the petcock mounts to the tank, you can use standard o-rings.  If it's leaking from the selector lever, you'll need the internal packing rubber (rubber disk with four holes in it), which is often available on ebay.
mystic_1
- John Augustus Shedd
« Reply #3 on: August 20, 2008, 11:27:22 PM »
All the "O" rings, and the complete valve id the same as 750 and still available from Honda
