Author Topic: Lots of chain noise  (Read 985 times)
Offline Leemata
Lots of chain noise
« on: August 20, 2008, 05:08:49 PM »
My '78 750F is in need of a new chain and sprockets.  That much I know for sure.  Right now the chain has tight & loose spots when trying to adjust it.  It's also making quite a bit of noise while riding it.  Will the new chain & sprockets take care of these problems?  Help is always appreciated.
Terry
'78 CB750F, '72 Honda Z50, '74 Honda Z50, '78 Maico MC250, '98 Yamaha YZ250, '75 RD350B
"Ah yes, Harley Davidson.  You really have to give them credit.  They've managed to create a market in which they can sell yesterday's technology at tomorrow's prices." (Michael Kasmirsky)
Offline CBJoe
Re: Lots of chain noise
« Reply #1 on: August 20, 2008, 05:36:54 PM »
Have you checked your rear wheel alignment?  Make sure that the adjusters are at equal positions on the left and right?
Joe
'07 Bonneville Black
'65 CB77
'66 CM91 (C90'ish)
Offline LoopsAndLogic
  • Dang IT!!!
« Reply #2 on: August 20, 2008, 05:54:33 PM »
Chains almost NEVER and I do mean "Never" wear evenly.
I've never came across one in all my 16 bikes that I've owned that had didn't have tight spots.
You should look for the tightest spot, and adjust it from there. Making sure you get the proper amount of slack per your
SOHC.
I even put on a set of new sprockets and chains on my 400F, and there was still, a slight tight spot.
 But it was only tighter by 1/4 to 1/2 an inch. So new hardware is always the way to go.
It also depends on what condition your back tire is in. I could be out of round because of a worn bearing or a slightly bent axle.
Many factors play in this, your job is to look over everything thoroughly.
Cheers mate
LL
My rides:
75' 76' Honda CB400F Super Sports
86' Honda XR600R for Street Madness
84' Honda Interceptor VF500
Past Rides:
80' Honda CX500C Fully Dressed
81' Honda CB650C very nice!
83' Kawasaki KZ550 A3
78' Hondamatic 400 Hawk
80' 81' 82' Honda GL500 Silverwing Insterstate
Offline Johnie
« Reply #3 on: August 20, 2008, 06:50:18 PM »
If you want a quiter chain try a good quality O-ring chain.  And of course, you will need new sprockets.  I can not even hear my chain now.  You may want to change that chain sooner than later as you do not want to have it break on you.  Or you will have another big problem...  Good luck with it.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Leemata
« Reply #4 on: August 21, 2008, 04:09:47 AM »
I have the rear wheel adjusted as evenly as I can using the measurement technique.  Rear tire was new less than 1K miles ago.  Chain slack measured with the bike off the stand and with me sitting on it.  Slackness varies pretty dramatically as the chain makes it's way around the sprockets.  I have to suspect wear in the chain/sprockets.  Like I said, I know I need them........just wanted some reassurance that should fix the noise problem.
Thanks!
Terry
Offline Hush
« Reply #5 on: August 21, 2008, 05:23:50 AM »
Sounds like at least your rear sprocket is coozed, replace that first and I bet your noise and tight spots disappear.
« Reply #6 on: August 21, 2008, 05:44:22 AM »
Thanks!
Terry
Leem:
I could write a book about this topic and the things I've learned about chains and sprockets (oh, wait, I'm already doing that...), but here's a few tips to help you understand the 750 (and loops, check this on the 400, too...):
1. Buy prestretched chains. To my knowledge, the only people who actually do a good job of this is Diamond, who also invented this process. Other companies sometimes claim they do it, but one thing you can bank on: if the chain costs less than the rear sprocket, the company did not take the time (or build the equipment necessary) to prestretch the chain. This important process aligns all the internal components (800 parts in a 100-link chain) before you get it.
2.Use Honda's own sprockets on the 750. They are specially designed to cope with this bike's suspension and power train. Several points they show: tapered teeth tips (to cope with the rubber-mounted rear hub), larger-than-SAE base circle (to decelerate the chain gently upon arriving at the sprocket), and hardened steel teeth surfaces (to extend wear). There's more, like accuracy of hole patterns, concentricity, and some others...
3. On  SOHC bikes: check the alignment of the rear hub. This can be done by centerstanding the bike in neutral and spinning the rear wheel while you watch from behind. The sprocket may wobble, instead of running true and parallel to the wheel: this means the hub is not fully seated. It is retained in alignment by a rubber O-ring on the brake drum (hard to 'click over it', both on and off), and the rubber blocks and aluminum fingers probably need some cleaning up and a little silicone spray to get them to slip together again after all these years. That's the only way I know of to get them to properly realign and stay that way: occasional disassembly, cleaning, and silicone lube. The hi-PSI car washes get that soap inside, and this causes problems over time. Cleaning works.
For the record: my favorite chain is Diamond's Powersport series, non O-ring. I've received as much as 40,000 miles from these chains, and at about $80 apiece, worth every cent in smoothness, quiet, and even wear over time.
« Reply #7 on: August 21, 2008, 05:50:10 AM »
Tsubaki 530 QR are pre-stretched, and hold up well.
A buddy running Diamond, got 40,000 miles  on one chain..
