Author Topic: 1972 CL350 - Headlight Size? Recommendations for H4 replacement?  (Read 4737 times)
Offline JeyLux
    • www.rustydelux.com
I've googled the crap out of this.
What size is the headlight on a 72 CL/CB 350?  I don't know where to measure from/to and i get anywhere from 5 to 5 3/4"
I want to throw an H4 into it so i can actually see something.  Yes I am aware of the weak charging system etc etc.  Just looking for bulb size? Thanks!!!
1973 CB500k
1972 CL350
Offline Green550F
  • Nothing is as cool as that which you made.
Re: 1972 CL350 - Headlight Size? Recommendations for H4 replacement?
« Reply #1 on: August 22, 2008, 05:55:45 PM »
good luck on the H4 search. The OEM bulb is 35W, but I haven't seen an H4 under 50W yet. If you change all other bulbs to LEDs you may make up the difference.
93 Kawasaki Voyager XII
70 Honda CL350 Cafe
Offline JeyLux
« Reply #2 on: August 25, 2008, 09:03:32 AM »
I've replaced everything with LEDs.
I'm hoping to find something.
I found a post somewhere saying it was a 154mm light ?? sound about right?
1973 CB500k
1972 CL350
Offline tbpmusic
« Reply #3 on: August 25, 2008, 09:11:09 AM »
I think it's  the 5 - 3/4" version. Most Hondas used that size until about 1971-1972, when they went to the 7" lamp.
Your headlight rim should measure about 7" or so overall, right??
bill2
Bill Lane
