Author Topic: What causes this? Pic attached  (Read 1910 times)
Offline i_m_jon
« on: August 23, 2008, 01:39:54 PM »
While investigating a leak under the left side cover, I found this. The front sprocket/chain is apparently making contact where the clutch cable attaches, which I just can't imagine is a good thing. Any ideas of what I might need to fix/replace (besides the leaky seal)? Thanks in advance.
Re: What causes this? Pic attached
« Reply #1 on: August 23, 2008, 01:46:33 PM »
Never saw that in a chain saw before...
Offline i_m_jon
« Reply #2 on: August 23, 2008, 02:02:00 PM »
Thanks. It's a CB500.
« Reply #3 on: August 23, 2008, 02:08:09 PM »
Do you have an Oring type chain?
Offline i_m_jon
« Reply #4 on: August 24, 2008, 06:21:45 AM »
I just checked that out and it's not. There's barely any space between the links.
Offline CB500_k2
  • Wrenching makes a good retirement.
« Reply #5 on: August 24, 2008, 07:30:38 AM »
I saw this on my CB500.  I replaced the chain with a new O ring chain with a removable link.  The shafts on the removable link are a little longer and they contacted the cable attachment part.  Got a chain riveter and a new link and fixed the problem.  The same situation may apply to a standard chain.
Too many bikes -- too little time
1973 CB500
1974 CB350 - sold
1975 CB400F SuperSport
2000 Ducati Monster Dark
Offline number13
  • 1973 CB500, 2002 VT750DC
    • Sound Exchange
« Reply #6 on: August 24, 2008, 09:33:41 AM »
It may also be caused by a shortened clutch push rod.
As they wear they become shorter.
The cable cinch is crashing into the chain because it has to
be adjusted too far out to compensate for the worn push rod.
Bikes parked out front mean good chicken-fried steak inside.
« Reply #7 on: August 24, 2008, 10:28:06 AM »
Is the ball bearing missing from the hole?
Offline i_m_jon
« Reply #8 on: August 24, 2008, 01:43:48 PM »
Ball bearing? Never saw one. That missing or the rod being worn would definitley cause this problem. Thanks for the all of the tips so far. I'll report back next chance I get to inspect it.
Offline i_m_jon
« Reply #9 on: August 25, 2008, 08:51:12 AM »
OK, here's what I've found. The ball bearing is in place. Here are some pictures of both ends of the push rod; it kind of looks broken off to me.
Offline number13
    • Sound Exchange
« Reply #10 on: August 25, 2008, 09:13:12 AM »
Yeah, that looks bad.
Time for a new one.
Offline i_m_jon
« Reply #11 on: August 25, 2008, 11:14:39 AM »
Time for a new one.
A new one it shall be. Thanks guys.
