Author Topic: 1975 CB750F - Here Goes Nothing - Pretty Much Done - Update 3/7/09  (Read 14066 times)
Offline KB02
Re: 1975 CB750F - Here Goes Nothing...
« Reply #50 on: November 03, 2008, 09:18:12 AM »
I saw the post in the other section. Probably a ground through the housing type light.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline uwjberg
« Reply #51 on: November 17, 2008, 12:43:28 PM »
update - i've been working piecemeal the past two weeks to finally finish her up. let's start with the seat. i cannibalized the seat the PO had on there, and cut the foam to fit the new seat pan.
i glued a layer of carpet padding on the top like so:
then covered it with the vinyl that was left over:
not the prettiest job, but it was $0, so that's a success in my book. i may have a professional look at it later, but this will work for now.
time to address the front fender. i had carpy's bobbed fender painted with the rest of the tins, but i needed to fit the brace from the original. since i didn't have the original, i scored one of ebay:
the dremel took care of the rivets...
i took the brace to the wire brush, and here it is, ready to mount:
drilled a few holes in my nice new fender, and we are ready to install.
Offline uwjberg
« Reply #52 on: November 17, 2008, 12:58:51 PM »
then i took care of a few small things - mounted some bar end mirrors, installed the shorter throttle and clutch cables, applied the honda tank decal, etc.
i hit a few snags with how it ran... after some head scratching, it turned out that i had screwed up the coil/plug wire order, so the firing order was all jacked up. i fixed that, and all seemed well. took it for a ride around the block, and when i got back, it was puking fuel out of the carb overflow tubes, and out of the carb body by the airbox boot, if you can believe it. soem friends helped me sort that out - the floats were hung up, so a little sandpaper on the pins, and it freed up nicely.
during the tuning, it was still really low on power, and we realized that it was only running on two cylinders - #1 and #4. when we swapped the coil wires, #2 and #3 were running, so we diagnoses a bad coil. this is a surprise, because they are brand new dyna usints. i called dynatek, and they agreed to take it in for testing. hopefully i hear from them soon, and i can have it up and running for the weekend.
in any case, i got her registered for use, and the cosmetic stuff is done - once the coil is in, i'll pronounce the project done for now. here are some pics of the way it looks currently.
Offline Really?
Re: 1975 CB750F - Here Goes Nothing - Pretty Much Done
« Reply #53 on: November 17, 2008, 01:29:22 PM »
Wow, really nice work.  I really like it.
I have wanted to see Carpy's fender mounted and painted like that too.  Thanks.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline DollarBill
« Reply #54 on: November 17, 2008, 01:33:14 PM »
Awesome job!  I dig the green and black...the whole thing looks really clean.
1975 CB750F Project Yellow Jacket - CBR600rr Swinger GSXR 600 Forks
1955 BMW R25/3, 1966 Honda CA160, 1975 CB400f, 1975 CB550, 1976 CB550
Offline Artfrombama
  • Card-carrying, board certified
  • CB750 K2
« Reply #55 on: November 17, 2008, 01:48:32 PM »
Nice ;D
Halfassed machinist
Tinkerer/goof-off/Mr. Fix-it
CB750-2011594 Sunrise Flake Orange
CB750E2441103
Offline uwjberg
« Reply #56 on: November 17, 2008, 02:55:00 PM »
thanks guys. i have four months into this thing, and am very satisfied with the result. i plan on riding it as a daily commuter. i'm looking forward to riding the snot out of it!
Offline CBJoe
« Reply #57 on: November 17, 2008, 03:53:35 PM »
 :o
I don't know how I didn't see this thread in the works. My hat's off to you.  I've got a couple CB650's in the garage for similar rebuilds this winter and I can only hope to achieve the final product that you have.
Beautiful freakin' bike   ;)
I hope that you didn't toss the original bodywork.  You should PM me in the spring (when i have money ::)) and offer it to me  ;D
Cheers....Joe
'07 Bonneville Black
'65 CB77
'66 CM91 (C90'ish)
Offline uwjberg
« Reply #58 on: November 17, 2008, 04:09:25 PM »
hehe. thanks. unfortunately, i did toss the bodywork already. after i had ripped the seat off, i couldn't justify the space in the garage. too bad - i would have just shipped it to you....
Offline Tim in Ohio
  • So I got that goin' for me, which is nice.
« Reply #59 on: November 17, 2008, 05:05:15 PM »
That is a badass looking bike my friend... good job!
1973 Honda CB350  Four
Check out my CB350F resto project...  watch a complete moron build a bike in front of your very eyes!: http://forums.sohc4.net/index.php?topic=38903.0
Offline UnCrash
  • Pass
    • My Blog
« Reply #60 on: November 17, 2008, 05:20:13 PM »
Great work!
Offline CBJoe
« Reply #61 on: November 18, 2008, 03:38:54 AM »
'65 CB77
'66 CM91 (C90'ish)
Offline uwjberg
Re: 1975 CB750F - Here Goes Nothing - Pretty Much Done - Update 3/7/09
« Reply #62 on: March 07, 2009, 04:02:35 PM »
OK - update time! Did some smaller bits that were bugging me. The stock speedo wasn't working, and I thought they looked a little big, so I changed the stock gauges to the smaller chrome ones from cycle-x. Work very nicely, and I think they look miles better than the stock units.
I also did some other cosmetic stuff - I added rear turn signals to fill that funky F rear subframe space and hole, adjusted the seat to be more level, switched the clip ons for clubman bars, and added a black stripe. Let me know what you all think....
Took her for the first shake down run today, and she did very well. Looking forward to putting some serious miles on her very soon. I also picked up another wiring harness off ebay for cheap, and I'm planning on redoing the harness and stripping it down to just the essentials over the Summer. Will solder all the connections, update the fuses, etc. I'mm try to install it when it gets really hot here in Vegas so I don't miss any riding time.
Offline imamotohead
  • Nuthin a little duct tape won't fix!?!
« Reply #63 on: March 07, 2009, 08:46:54 PM »
Awesome work!  My 750F project is still in the apart phase.  I was wondering how you finally decided to mount your Carpy seat.  Photos please!  Also do those cycleX guages work with the stock tach and speedo cables?  Thanks for the update. ;D
Here today, gone tomorrow.  Make the most of today!
fuzzybutt
« Reply #64 on: March 07, 2009, 11:46:18 PM »
since i'm lazy and dont want to go through the entire thread, i'll just ask. what header is that?
Offline uwjberg
« Reply #65 on: March 08, 2009, 07:26:26 AM »
thanks, guys.
imamoto - i epoxied a piece of 3/4" think plywood to the underside of the seat, and used heavy duty velcro between that and the frame. works well, and it's still convenient to take on and off as needed. i'll try to snap a photo today if i can. the cycle-x gauges were a direct fit with the cables - very easy to install.
fuzzy - the exhaust is stock. earlier in the thread i have a few pics to show. i just used the stock header and inserted a generic baffle from denniskirk.com, then topped it with a exhaust tip from autozone. cheap, and it sounds pretty good.
masonryman
« Reply #66 on: March 08, 2009, 07:48:14 AM »
I may have missed it. Did dyna replace the coil?
Great bike, Great build enjoyed reading it.
Mark
Offline scartail
« Reply #67 on: March 08, 2009, 07:51:38 AM »
That's a really nice project you have there. Just curious, how did you attached your seat?
'89 Hawk GT, newly acquired, daily beater...
'76 CB550, was my daily beater... my cafe project...
'72 Yamaha R5, newly acquired project... donated to my buddy...
'67 Suzuki T20, still working on her too... Currently in pieces...
Offline uwjberg
« Reply #68 on: March 08, 2009, 08:05:18 AM »
masonry - dyna looked at it, but found it was ok. the problem ended up being a wire that the PO had piggybacked off of the coil power wire to hook up god knows what. it was drawing enough cuurent from the coil to have it not fire completely m- thus, me thinking that the coil wasn't working. simply a matter fo cutting the wire, and voila! took a few hours of tracking down with a multimeter to find the culprit. more reason for me to make a new harness from the ebay one, to eliminate any other questionable wiring.
scar - the seat itself is mounted to the fiberglass tail with  more heavy duty velcro. it's a temporary set up until i can get the seat properly upholstered. that being said, that velcro holds really well, and it's not going anywhere.
Offline 78CB750CAFE
  • I'm not really an
  • Ride, wrench, repeat.
« Reply #69 on: March 08, 2009, 08:11:59 AM »
luvely!
very clean and well thought out, nice bike, congrats!
Offline scartail
« Reply #70 on: March 08, 2009, 10:32:16 AM »
As long as the fiberglass seat is secured well, the cushion is just for extra comfort. I think I will go down the velcro route as well for my project. Thanks.
How did you mount the seat btw.
Offline luder
« Reply #71 on: March 08, 2009, 10:54:42 AM »
Very nice I like it-good job.....luder
