Author Topic: Tank painting question  (Read 1001 times)
Offline captaincrash80
  • I better build something before I'm no longer considered a
  • Member #4842
« on: August 25, 2008, 08:18:16 AM »
I've got a tank I'm repainting for a CM400 and was wondering, what's the best way to get a "metal" look to the tank? I was planning on painting it matte black but when I put it on the bike after it was stripped I really liked to way it looked. I know I need to paint/protect it somehow. Ideas?
Offline mystic_1
  • 1970 CB750K
Re: Tank painting question
« Reply #1 on: August 25, 2008, 08:19:10 AM »
Spraymax clear coat?
mystic_1
- John Augustus Shedd
  • Member #4842
« Reply #2 on: August 25, 2008, 08:28:03 AM »
I was thinking about some kind of clearcoat, didn't know if anyone had tried it before/had any luck with it.
Offline goon 1492
  • Sucka Repellant
« Reply #3 on: August 25, 2008, 10:20:41 AM »
the only prob you might have is if you keep the tank smooth(polished) look and try to paint clear over that, you might have an issue with adhesion and a modifier might help with adhesion, I will check with our painters and try to post a tip before I leave work today.
  • Member #4842
« Reply #4 on: August 25, 2008, 10:24:00 AM »
Thanks goon, look forward to hearing what you find out.
Offline mystic_1
  • 1970 CB750K
« Reply #5 on: August 25, 2008, 10:42:36 AM »
If you go for a "brushed metal" look you should have no problems with adhesion.  Mirror-finish polishing would be a problem of course.  The original finish on the engine side covers was a brushed finish with clear coat.
mystic_1
Offline kghost
« Reply #6 on: August 25, 2008, 10:42:45 AM »
POR makes a Product thats supposed to stick to polished Aluminium and metal.
Eastwood sells thier Diamond clear that is also supposed to stick to bare metal.
Stranger in a strange land
Offline super pasty white guy
  • I'm not really a
  • 1976 750 F
« Reply #7 on: August 25, 2008, 10:46:22 AM »
If you spend some time searching (might have to spend a lot of time) there was another member who posted good results (with pictures) of his tank cleared with the POR product.  It looked darn fine.
spwg
Offline goon 1492
  • Sucka Repellant
« Reply #8 on: August 25, 2008, 10:53:06 AM »
Ok talked to the painters, we use mattews paint systems here and with painting metal surfaces clear and not scuffing the metal before they have to use whats called "spray bond" and spray on it before painting the clear, it wil give the mechanical adhesion needed. I'm sure there is similar products for dupont and other automotive applications. You could probably call a dupont paint store in town and they could tell you what you need to use. Oh yeah I saw your Pm and I am located across the street from the valero gas station, its called Dimensional Innovations, two buildings east of the overland park tow lot. ;D
