Author Topic: Play in the bottom tripple. What does it mean?  (Read 767 times)
Offline JerryRice
« on: August 25, 2008, 10:43:05 AM »
I finally get my forks fixed. Had the entire front end off.
Not I get it all back together. And notice a priblem.
With the bike on the centerstand. If i lean forward and
apply pressure on the front end..
The bottom tripple tree moves a little bit.
Does this mean that I need new bearings?
thanks in advance.
The Real JERRY RICE
My Dream Bike
www.CB350F.com
Offline mystic_1
  • 1970 CB750K
Re: Play in the bottom tripple. What does it mean?
« Reply #1 on: August 25, 2008, 10:49:11 AM »
Possible they just need to be adjusted.  Loosen the top tree clamps and top nut, then reach under the top tree with your shock adjusting tool and tighten down the retaining ring.  It should be tight enough to keep things from wobbling but not so tight that steering action becomes stiff.
mystic_1
- John Augustus Shedd
Offline JerryRice
« Reply #2 on: August 25, 2008, 11:04:15 AM »
Thanks. Which shock adjusting tool are you reffering to?
The Real JERRY RICE
My Dream Bike
www.CB350F.com
Offline mystic_1
  • 1970 CB750K
« Reply #3 on: August 25, 2008, 11:23:04 AM »
Looks like this:
But anything that'll let you turn the adjusting ring (#12 below) would work just fine.  The shock tool is nice because it's thin and clearance under the top tree is kinda tight.
mystic_1
Offline Johnie
« Reply #4 on: August 25, 2008, 11:46:02 AM »
Do not overtighten those Jerry.  Just a snug or you will damage them.  You will be tightening #12 on your parts list.  Not that top chrome nut on the tree.  I bet those bearings (#22) could use a little grease.  You can pack them with the triple tree on.  You just have to loosen it and drop it down a spec if you decide to do it.  Good luck with it...
« Last Edit: August 25, 2008, 11:47:59 AM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline JerryRice
« Reply #5 on: August 25, 2008, 11:46:20 AM »
Ahhh yes, the Spanner tool.
The Real JERRY RICE
My Dream Bike
www.CB350F.com
ev0lution7
« Reply #6 on: August 25, 2008, 12:44:37 PM »
or you can do youself a HUGE favor and buy some real bearings... tappered roller bearings! like i did and impove the front end TONS!
