If you installed an unmodified MAC of recent manufature, still have the stock airbox in place with a stock filter then you probably can get by without rejetting. At the most you may have to go from 105 mains to 110 mains. You really shouldn't have to change the slow jets. Now if you've opened the baffle up in the MAC and/or modified the air intake (such as drilled airbox or pod filters) then you'll have to increase the size of the main jets. I have a modified MAC with pods on my K2 and am running 135 mains with stock slow jets (40). Hope this helps.
