Author Topic: CB400A pistons stuck HALP!!!  (Read 946 times)
Offline captaincrash80
  • I better build something before I'm no longer considered a
  • Member #4842
« on: August 27, 2008, 09:16:56 am »
So last night I pulled the engine for my 78 CB400A 'Hondamatic' out from under the workbench (now that there's a place for it). I had already tore down most of the top half but had problems with the cylinders. Well last night I finally broke the cylinders loose from teh case but now I can't remove them  :-\ It appears that the pistons are stuck inside the cylinders (may be the piston sleeves). Any thoughts on how I might be able to get the cylinder off? Thanks in advance.
rhos1355
Re: CB400A pistons stuck HALP!!!
« Reply #1 on: August 27, 2008, 09:20:46 am »
There are loads of posts on this kind of problem. If you spend a few minutes doing a search on this site you can take your pick.
  • Member #4842
« Reply #2 on: August 27, 2008, 09:49:37 am »
Any suggestions on a search string? All mine are coming up with nothing useful  :(
rhos1355
« Reply #3 on: August 28, 2008, 10:44:44 am »
Hi Captain, yup you're right; I had to think of every description regarding stuck pistons and very little came up. But I was sure that I'd seen numerous threads like yours. So finally, when my brains got into the proper gear I tried "seized engine" and hey presto 5 pages of propmpts came up! Good luck.
