Author Topic: Thought you guys would like to see what I've been up to......  (Read 1278 times)
Offline captaincrash80
  • I better build something before I'm no longer considered a
  • Member #4842
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
Re: Thought you guys would like to see what I've been up to......
« Reply #1 on: August 27, 2008, 10:46:31 am »
Looks nice!  Are those Harley controls?
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
  • Member #4842
« Reply #2 on: August 27, 2008, 10:53:04 am »
Yeah, everything on the frame came off a bobber project that I purchased. The PO of the bobber had pretty well mangled the frame, so I tranferred everything over to an extra CM400T frame that I had. Only problem w/ the hand controls is that I can't for the life of me figure out how the brake lever mounts to the MC, it just doesn't fit right  >:(
Offline kslrr
« Reply #3 on: August 27, 2008, 10:55:47 am »
What is the issue with the brake lever?  Too loose, too tight?  Is it the correct lever?  Take some pics of the level in the MC so that we can lend a hand.
        1981 CB650 engine
Then 1972 CL175
        1964 Yamaha YGS-1T
  • Member #4842
« Reply #4 on: August 28, 2008, 07:08:31 am »
Sorry it took so long, camera was being screwy and I ended up having to use my phone camera  :P. So here's the deal: The lever looks like it should be the correct one. The problem is that when I place the lever in the MC I can't 1. get the pivot pin in to attach it and 2. the lever doesn't seem to be actuating the MC at all
There's a small nub coming off the bottom of the handle that prevents the handle from really going anywhere
I've run out of ideas, short of taking the whole damn thing up to the HD dealership and having them show me. Also can't find any exploded view diagrams/instillation instructions for any of the HD MCs anywhere. Thoughts?
Offline kslrr
« Reply #5 on: August 28, 2008, 12:02:05 pm »
Here's some pics of the MC on my Sportster for comparison of how it fits in..  I do not see a nub like on yours.
Edit: upon closer look at yours, it looks like your lever is like mine, but your MC is not.  Maybe you have 2 different years and the design was changed along the way.
« Last Edit: August 28, 2008, 12:03:54 pm by kslrr »
        1981 CB650 engine
Then 1972 CL175
        1964 Yamaha YGS-1T
