Author Topic: Dual front disc shopping list  (Read 1638 times)
Offline XN
« on: August 27, 2008, 12:27:34 PM »
So I've read the how to do it, but still wondering what exact parts will swap over So what years discs, caliper, caliper brackets will work on my 78 CB750K? I'm assuming that it must be from a K and not and F correct?
Thanks.
78 Honda CB750K
02 Yamaha V-star 650
02 Honda VTX 1800
Offline shoemanII
  • just another bike nut
Re: Dual front disc shopping list
« Reply #1 on: August 27, 2008, 02:01:49 PM »
my '78F discs are 5 bolt, the '78 K's are 6.
that said, i do have a single disc and caliper arm/bolts in nice shape from my '78 parts bike, listed in the "for sale" section.  no caliper tho, bleed screw was extremely FUBAR'd so i tossed it.
bobp
robert.pirie@state.vt.us
'96 ducati carb'd 900ss/cr
'72 dt2
'77cb550k frankenberry:  '77cb550k frame, '78cb550k engine, '78cb550f tank, unknown front-end
Offline low-side
« Reply #2 on: August 27, 2008, 02:55:17 PM »
With a '78 750K, your caliper and brackets will interchange with '77&'78 Ks and '75 &'76 Fs.  The earlier Ks had larger calipers and the later Fs have completely different calipers and rotors.  While your at it, I would turn your calipers around so that they face the engine to reduce front end vibration and generally improve braking.  I would also reccomend using a 5/8" piston master cylinder (like off a '78F or a GL1000) and braided stainless lines.  It works better and has better feel.
Offline XN
« Reply #3 on: August 27, 2008, 08:37:16 PM »
bobp
Sold! I sent you a Email.
78 Honda CB750K
02 Honda VTX 1800
Offline XN
« Reply #4 on: August 27, 2008, 08:40:30 PM »
OK so being I'm going with a 77/78 K caliper mount must I stick with a 77/78 caliper or could I also use a 75-76F caliper too?
Yep my plans are to use a new 14mm bore master cylinder with braided lines.
78 Honda CB750K
02 Honda VTX 1800
Offline low-side
« Reply #5 on: August 28, 2008, 09:02:37 PM »
Yeah, to turn the calipers toward the engine you need to swap the tubes.  For your fender to face the rightway you need to grind out the rivets and turn it around on its mount.  I eliminated the adjustment screws at the time I did it; I never noticed a benefit from them anyway.  If you have anymore questions just ask.
Offline XN
« Reply #6 on: August 28, 2008, 09:04:39 PM »
What about the caliper with the 78 K mount can I still use a 75-76F caliper?
78 Honda CB750K
02 Honda VTX 1800
