Author Topic: Engine Dowel Pins Source  (Read 2705 times)
Offline SD750F
    • My Business Site
« on: August 28, 2008, 05:01:17 PM »
Looking for a source for those various sized dowel pins used to aligned engine cases and covers. Most of the part stores where you enter the PN's will indicate that they have them until you check out and they void the purchase because one or more of the parts selected are no longer available...
Maybe I can use nothing more that stainless steel tubes with the correct O.D.???
Scott
Offline brazwell
  • Honey, everytime I ride my bike, god saves a baby turtle.
Re: Engine Dowel Pins Source
« Reply #1 on: August 28, 2008, 05:08:59 PM »
I am having the same problem currently with my 750 k3 rebuild. Need one of the corner dowels between cylinder and head. Absolutely unavailable. My next attempt will be measuring said dowel ( think its 14x22mm), and trying to match it up. Lots of online sources for random dowels.
73' CB750
49' Panhead El
Unicycle (w/ flat tire)
« Reply #2 on: August 28, 2008, 05:44:13 PM »
Just drop by your local Honda shop, they're apt to have loads of used dowels.
Offline Patrick
« Reply #3 on: August 28, 2008, 05:56:41 PM »
I actually found dowels with the correct diameter (12mm) for my K0 750 build at a local dirt bike shop. They only had one size, but it was the right length for the longer dowels. They looked exactly like stock. I had to cut two other down a bit with my Dremel to make the right length for the shorter ones, but they slipped in just fine. Try other part shops. You might get lucky.
Patrick
« Last Edit: August 28, 2008, 06:38:31 PM by Patrick »
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline rhinoracer
« Reply #4 on: August 28, 2008, 06:35:19 PM »
I bought a few dowels when putting the engine together last year from the Honda dealer. In fact some of these are still used on late model engines (CBR600) so they even had some sizes in stock.
Baja native.
Offline SD750F
    • My Business Site
« Reply #5 on: August 28, 2008, 06:41:51 PM »
I did a little more research after a light bulb idea. http://www.mcmaster.com/ has a great metric dowel selection in either stainless or plain steel from 1M to 20M diameters with a great variety of lengths...
Scott
Offline kghost
« Reply #6 on: August 28, 2008, 08:11:20 PM »
CMS has those 12 mm dowls if your too lazy to hunt for them
http://www.cmsnl.com/products/pin-special-12mm_12116300000/
Stranger in a strange land
Offline mystic_1
  • 1970 CB750K
« Reply #7 on: August 28, 2008, 10:38:23 PM »
Make sure to use anti-seize if you go for the stainless dowels in order to avoid galvanic corrosion.  Personally I'd suggest the mild steel ones.
Also, McMaster's dowels seem to be solid rather than hollow, wonder if that'd make a difference with anything.  I mean, aside from actually being able to remove them at a later point in time without crushing them :)
mystic_1
Edit:  Never mind, they have "pull-out" style dowels that are hollow, and have a much better wall thickness than the stock honda knock pins :)
-m
- John Augustus Shedd
Offline Steve F
« Reply #8 on: August 28, 2008, 11:01:26 PM »
Another potential problem is, according to APTECH77, you have to be sure they're not too long.  He had a problem with that when putting the head back on his 400, and oil leaking everywhere.  Turned out the dowels bottomed out and kept the head and the gasket from sealing.  He actually bent one or two.
Offline oldbiker
  • I HATE RAIN
« Reply #9 on: August 29, 2008, 01:02:54 AM »
Just turn them out on a lathe
Offline KB02
« Reply #10 on: August 29, 2008, 04:42:50 AM »
Ahhhh.... to have a lathe...    ::)
Actually, that would probably be dangerous for me.  ;D
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline SD750F
    • My Business Site
« Reply #11 on: August 29, 2008, 06:49:01 AM »
Actually the McMaster-Carr items I was looking at were hollow but had internal threading to aid in removal... Great idea! Eliminate the one problem that destroys the existing ones in the first place.
And I would use anti-seize on any stainless I would use. Same stuff I am using on all my stainless bolts.
Scott
Offline mrosso
  • The before picture.
« Reply #12 on: August 29, 2008, 10:19:35 AM »
Did you try hondaparts-direct.com? I think they still had most in stock.
Offline brazwell
« Reply #13 on: August 29, 2008, 05:36:04 PM »
Good call mrosso, just ordered one from Honda Direct. Over $9 for shipping! Well see if I receive an email tomorrow stating its unavailable....
73' CB750
49' Panhead El
Offline brazwell
« Reply #14 on: September 02, 2008, 06:49:30 PM »
Just got the email, unavailable through Honda-Direct! Were going to have to get creative.
73' CB750
49' Panhead El
Offline kghost
« Reply #15 on: September 02, 2008, 07:14:39 PM »
Ummmm....why don't ya just order them?
Offline brazwell
« Reply #16 on: September 13, 2008, 03:27:06 PM »
Holy mother of god, $36 shipping......
73' CB750
49' Panhead El
Online Jerry Rxman Griffin aka MuthaF'er
« Reply #17 on: September 13, 2008, 11:18:15 PM »
TAS (one of our members) has 2 separate listings for 1 each on EBay with a buy it now of ~$3. Search for him here or search "honda nos" on EBay.
Offline brazwell
« Reply #18 on: September 14, 2008, 01:32:48 PM »
Unfortunately wrong size. Need the corner dowels, 12x22mm.
73' CB750
49' Panhead El
