Author Topic: took front break caliper apart  (Read 1477 times)
Offline cadaver
« on: August 31, 2008, 10:44:25 AM »
OK now that I was able to get the caliper apart and cleaned out the rust and other crud .. I cant get the piston back in ..the rubber seal wont let the piston threw...anyone have a trick that you know of . or do i just half to go and buy another seal because that one is warped out ?
Offline ieism
Re: took front break caliper apart
« Reply #1 on: August 31, 2008, 10:49:18 AM »
Take the caliper completely off. Make sure you've cleaned out the groove that holds the seal> put a little coppergrease on the seal and put it in the caliper. Put a little coppergrease on the inside of the seal.
push in the piston STRAIGHT. It takes a little force, that's normal.
---cb550---
Offline cadaver
« Reply #2 on: August 31, 2008, 10:53:58 AM »
OK ..ill go out and try that ..but I've gotta run and get some copper grease.  I was just wandering, why copper grease and what is the difference in that and other greases ?
Offline ieism
« Reply #3 on: August 31, 2008, 11:02:29 AM »
Copper grease is heatresitant. I'm not sure what happens when normal synthetic grease gets in contact with brakefluid. It might corrode or something.
These are your brakes, so don't take any chances.
Just go to a car mechanic/shop and ask him for a little coppergrease. You need less that half a tablespoon, so he'll likely give it to you for free.
---cb550---
rhos1355
« Reply #4 on: August 31, 2008, 11:05:09 AM »
Better still, buy a spraycan of the stuff and keep it handy for any future greasing jobs
Offline lordmoonpie
    • Moonpie
« Reply #5 on: August 31, 2008, 12:25:50 PM »
I think it's more a case with normal grease the heat makes it fluid and it gets everywhere - including on your brake pads. Copper grease stays put and works without putting your neck on the line!  :o
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
Offline Raul CB750K1
« Reply #6 on: August 31, 2008, 01:31:51 PM »
To put the piston back in, once the caliper and piston has been thoroughfully cleaned, I simply use brake fluid as lubricant.
« Reply #7 on: August 31, 2008, 01:35:54 PM »
Why wouldn't copper grease contaminate the brake fluid?
I use brake parts assembly fluid.  Made specifically just for the task.
Offline cadaver
« Reply #8 on: August 31, 2008, 07:27:57 PM »
well i went to one of the auto car parts stores around where i live and i didn't see copper grease..and the guy kinda looked at me funny when i asked about it ..but than again maybe he just works their and takes the money ...but i used a lithium grease all purpose ..just a dab and use a C clamp and it worked its way in ...put it all back together and i hope that later on that i can stop  :o....but so far when i pull in the break it Locke's up ..and when its off it rolls ..thanks for the help
Offline Artfrombama
  • Card-carrying, board certified
  • CB750 K2
« Reply #9 on: August 31, 2008, 11:46:47 PM »
I used a dab of silicone brake grease and slid right back in with two thumbpower.
Copper grease is a new one on me, must be a European product.
Halfassed machinist
Tinkerer/goof-off/Mr. Fix-it
CB750-2011594 Sunrise Flake Orange
CB750E2441103
Offline oldbiker
  • I HATE RAIN
« Reply #10 on: September 01, 2008, 12:06:27 AM »
If you google 'Granville oil', and look in products/grease you will find copper grease. The makers claim it is good to prevent corrosion especially in hot areas. They also say it stops brake squeal when applied on the back of brake pads.
Offline bradweingartner
  • 74 CB 550 x2
« Reply #11 on: September 01, 2008, 07:06:17 AM »
I always use brake fluid as lubricant too.
If you hook up the brake systems and THEN fill and insert the caliper piston, you eliminate most of the air out of the system in one step. Bleeding is seldom necessary!
Offline fmctm1sw
« Reply #12 on: September 01, 2008, 07:35:09 AM »
Try buying a new seal.  Made all the difference in the world for me:  http://forums.sohc4.net/index.php?topic=27842.0
I bought a new seal and it went right in with a little brake fluid n it...
« Last Edit: September 01, 2008, 07:37:10 AM by fmctm1sw »
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline cadaver
« Reply #13 on: September 01, 2008, 09:32:44 AM »
thanks guys for all your input ...but when most of my bike parts come in ill order a new seal and break pad for front and back ..bike has taken way to long to get on the road  :'(
« Reply #14 on: September 01, 2008, 09:38:40 AM »
Won't lithium grease make the caliper seal swell up?
  • 74 CB 550 x2
« Reply #15 on: September 01, 2008, 10:31:14 AM »
I've never been foolish enough to try, but I know I won't be putting anything besides brake-specific fluids and goops anywhere near my brake system when it's pretty much the one useful brake I got.
Offline cadaver
« Reply #16 on: September 01, 2008, 10:34:47 AM »
i didn't know if it would but i pulled the seal out and cleaned all the stuff that was in that ring with a dermal ..and i put the seal back in and pushed the piston back in . put it all back together and works for the time being ..when i get my new parts for the front break i don't think that ill use that grease if it makes the seal swell up ..thanks for the advice
