Author Topic: GL1000 problem...  (Read 1820 times)
Offline bert96
  • past ride
GL1000 problem...
« on: August 31, 2008, 12:44:04 PM »
 The engine run only on 3 cylinder,the cyl #2 is the problem but i have 130 of compression,i have spark and fuel,i know it sound weird and it should run well...any idea  ??? ??? ??? ??? ???
QA50 1969,ST-90 1974,mb5 1982,rz350 1983,shadow 1100 1985,vf1000f 1985,BMW K1 1990,shadow tourer 1100 2001,vfr 750 1994,vtr250 199?
Offline 333
  • Time for change
Re: GL1000 problem...
« Reply #1 on: September 02, 2008, 07:38:40 PM »
Have you made sure there's no water in the #3 carb?  How about checking the valve clearance?
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline kghost
« Reply #2 on: September 02, 2008, 08:20:31 PM »
I hate Goldwing carbs.........
Theres a seriously crazy amount of passages in them and thier CV to boot.
First off....did you clean the carbs?
Go to Randakks page. He has instructions and kits/
 http://www.randakks.com/
http://www.randakks.com/TechTips.htm#A
Stranger in a strange land
Offline bert96
  • past ride
« Reply #3 on: September 03, 2008, 05:39:15 AM »
 We have install 2 weber IDF 40(brand new!) and the intake from Randakk.
Offline bert96
  • past ride
« Reply #4 on: September 03, 2008, 05:41:44 AM »
 I think the valve clearance is good because i have a good compression,there is no water in the carbs(2 webers),they are new from the box :)
Offline 333
  • Time for change
« Reply #5 on: September 03, 2008, 08:59:44 AM »
But 130 isn't that good.  OK, but not great.  There has to be some reason for it not to be firing.  Maybe the plug itself.
Offline kghost
« Reply #6 on: September 03, 2008, 09:51:15 AM »
You try pulling the plug...sticking the cap back on...and grounding it to the frame.
Then cranking to see if that plug was actually firing?
Offline bert96
  • past ride
« Reply #7 on: September 03, 2008, 11:02:06 AM »
yep,and the spark is good ???
Offline kghost
« Reply #8 on: September 03, 2008, 03:08:30 PM »
I know alot about GL1000's...I had two of them.
But I don't know squat about those Downdraft Webers....
If you have spark...its gotta be that its not getting fuel.
If I recall correctly from pictures at nakedgoldwing and randakks site....
It feeds down each cylinder pipe individually....gotta think that 3 isn't getting gas.
Offline bert96
  • past ride
« Reply #9 on: September 03, 2008, 04:46:53 PM »
 yeah,more i think about that more i think is gas too,but i did not thought about that first because the carbs are new...anyway thanks for your helps guys,i will check that in my days off ;)
Offline 78 k550
« Reply #10 on: September 03, 2008, 05:41:36 PM »
just because the plug fire's doesn't alway's mean it can hold it or maybe week under load.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Offline kghost
« Reply #11 on: September 03, 2008, 05:43:12 PM »
Paul
Yeah but the other one is firing so it kinda rules out points and coil.
Offline 333
  • Time for change
« Reply #12 on: September 04, 2008, 08:01:35 AM »
Paul
I believe he's saying that the plug may still be bad.  I would suggest moving the plug and see if the problem follows the plug.
Offline bert96
  • past ride
« Reply #13 on: September 04, 2008, 08:09:12 AM »
I did,i replace the new plug with the old plug,still have the same problem >:(
Offline 333
  • Time for change
« Reply #14 on: September 04, 2008, 06:16:01 PM »
Then I'd go back to checking the valve clearance.  If it's not sucking in gas, it won't have any thing to fire.  It's got to be either lack of fuel or lack of fire.
