Author Topic: New Project  (Read 1200 times)
m goodwin
New Project
« on: September 11, 2005, 05:18:35 PM »
This site seems very impressive..  I am beginning to restore a 1974 750four with 5k miles totally original and in storage for last 23 years.
Outside of the tank, carbs and typical type stuff, what should I be looking hard at? and does anyone have any recomendations on places to get quality parts?
Offline Alan F.
Re: New Project
« Reply #1 on: September 11, 2005, 06:40:16 PM »
Go through the electrical system, those connectors get a bit dirty inside over the years, I cleaned each pin of each connector one at a time with a brass bristle brush then applied a coating of dielectric grease,  then placed each pin back where it was...lots of notes and sketches will help.  Another very important spot is the fuse holder, old solder for some reason will cause a high resistance condition resulting in a fuse with the end caps seperated, a melted fuse holder and maybe a hot blown fuse........the cure to this is simple, pop the fuse clips out of the plastic panel, and heat the solder up with a soldering iron or torch, when the solder melts knock the liquid solder against something and most of that old solder will seperate itself from the wire/fuse clip, careful it's very hot stuff. re-solder the connection and when cool, clean it with the brass brush and apply dielectric grease and reassemble.
Go through the connections in the headlight bucket, look for bad wiring/broken connectors etc.  clean and grease each connection.
replace the headlight/directional/brake/idiot light bulbs and flasher relay with new ones.....the idiot light bulbs are #52 not #57 like the books say.
this should get you on the right path to getting the bike back on track.
any other questions,  e-mail directly.
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
Re: New Project
« Reply #2 on: September 12, 2005, 01:13:30 AM »
Go through the FAQs carefully and read all about others' experiences. Then use the search function on specific activities (don't just search on "restoration" - you'll get thousands of references!)
Post a pic (before, during and after if you like) in the Gallery.
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
