Author Topic: Replacing Obsolete Early Front Fork Bushings  (Read 1514 times)
Offline Artfrombama
  • Card-carrying, board certified
  • CB750 K2
« on: September 02, 2008, 03:01:51 PM »
My 750K2 had two cracked and worn upper front fork bushings (51451-319-000). I found one NOS :(
A little measuring and I find an off-the-shelf 1 3/8" ID x 2" OD x 3 L bronze bushing fills the bill.
The outside diameter must be turned down to fit the lower legs.
Depending on the shaft size (+/- .002"), the ID may require a light hone.
The OEM material is cast iron, I feel that bearing grade bronze may be better suited.
Halfassed machinist
Tinkerer/goof-off/Mr. Fix-it
CB750-2011594 Sunrise Flake Orange
CB750E2441103
Offline bradweingartner
  • 74 CB 550 x2
Re: Replacing Obsolete Early Front Fork Bushings
« Reply #1 on: September 02, 2008, 04:23:41 PM »
Consider me interested to see how it works out.
I'm not sure the bronze is hard enough though? Maybe it is, what do modern bikes use?
Offline lordmoonpie
    • Moonpie
« Reply #2 on: September 03, 2008, 04:44:17 AM »
I got a set of forks from a breaker that were off a K0 and they had bronze bushings.
Nightmare to source these parts though so if you come up with a cheap option to source new ones I'm well interested in the how to...
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
Offline voxonda
« Reply #3 on: September 03, 2008, 05:06:10 AM »
Surely can make a set if I have the exact measures. Or send me one to look at.
Cheers, Rob
Offline Artfrombama
  • CB750 K2
« Reply #4 on: September 08, 2008, 07:42:19 PM »
Had to polish out a couple thou from the ID to interface with my new "Forking By Frank" fork tubes. Standard "off the shelf" $12. bronze bushing (x2).
Nice and tight, no slop.
Halfassed machinist
CB750E2441103
