Author Topic: Gasket is hard as a woodpeckers lips, and STUCK ON.  (Read 1285 times)
Offline chippyfive50
  • NO PEE ON TEPEE
    • thesweetimpala
« on: September 05, 2008, 09:12:44 PM »
got my 750 head/jugs off tonight...the base jug gasket is a #$%* to scarpe off..any tips??
SOHC Member#4000
71' 500K0 #1021237--E1108327
78' 550
72' 750K2(sold to "Craig")
74' 750K4 #2306334--E2303422
73' CL175
http://gallery.sohc4.net/main.php?g2_itemId=14013
Re: Gasket is hard as a woodpeckers lips, and STUCK ON.
« Reply #1 on: September 05, 2008, 09:17:45 PM »
I tried some carbon cleaner, I think it was from GM, that really worked well to loosen those stubborn base gaskets. I've got a favorite dedicated gasket scraper, time & lots of patience to not gouge the surface is the key.
KingCustomCycles.com
« Reply #2 on: September 06, 2008, 04:02:05 AM »
Stripper.  Paint type, or hire a local girl to do it for you.  ::)  +1 on that scraper, you can shave that aluminum like cheese if you aren't careful.
Offline heffay
« Reply #3 on: September 06, 2008, 08:41:04 AM »
flat razor blade
DON'T SCRATCH THE GASKET SURFACE!   ;)
rhos1355
« Reply #4 on: September 06, 2008, 08:55:42 AM »
Heh, Heh, heh. Took me a week to strip off what was left of my cylinders' gasket. Many's the evenings I could have wept in frustration. In the end it was just stripper (paint) long blade from stanley knife and patience by the barrow load. Never use the point of the knife, always draw the edge of the blade along the top at a shallow an angle as poss.
Enjoy.
Offline Patrick
« Reply #5 on: September 06, 2008, 10:33:37 AM »
Gasket stripper and 000 steel wool worked for me.
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline Scrubs
« Reply #6 on: September 06, 2008, 11:18:22 AM »
Loctite Chisel 790 works like magic.  it contains methylene chloride so wear gloves.. Be careful of paint etc...
