Author Topic: No pressure in rear brake...  (Read 2661 times)
LeoLegendATL
« on: September 12, 2005, 02:42:36 PM »
I just "fixed" my rear brake but have encountered a problem.  I have no pressure in the rear brake, the master cylinder pushes all the way up even when the bleed screw is tight.  I am losing no fluid either, I tried bleeding, but it seems air is leaking into the system.  or do I need to keep bleeding.  The brake slows the wheel a little bit but does not clamp, the master cylinder just bottoms out.  Any ideas?  Cb750f
eldar
Re: No pressure in rear brake...
« Reply #1 on: September 12, 2005, 03:32:09 PM »
Keep bleeding. It is possible that there is an air leak but if there are no fluid leaks, I would not think so.
Offline kghost
« Reply #2 on: September 12, 2005, 10:06:15 PM »
Sounds like a blocked orifice in the resevoir. (the small orifice).
Stranger in a strange land
Offline mcpuffett
« Reply #3 on: September 13, 2005, 01:16:34 AM »
or fluid getting past the seal internally  :-\ mick.
eldar
« Reply #4 on: September 13, 2005, 08:44:21 AM »
fluid seep may be possible but since there is no fluid leaking.. hard to say. Not sure about the orrifice since the lever bottoms. I would almost think there is a huge amount of air in the line but something could have been installed wrong that does not leak, but is not pushing the fluid.
LeoLegendATL
« Reply #5 on: September 13, 2005, 01:11:29 PM »
I took apart the rear master cylinder and put it back together cleaning everything, then as luck would have it, I torqued the head off the bleed screw in the back, great. Tried to drill it out, but now Im looking at a new caliper possibly.  Anyone know where to find one?
eldar
« Reply #6 on: September 13, 2005, 04:01:15 PM »
Your best source for price would be ebay or a bike junkyard. Otherwise if you can find one that fits for new, it will be hard and costly.
Offline scondon
  • Mmmm......tasty bugs
« Reply #7 on: September 14, 2005, 11:24:52 PM »
What year is your bike? I may have some 75-76 rear caliper bits about and most definitely have 77-78 calipers. F models.
LeoLegendATL
« Reply #8 on: September 15, 2005, 02:04:09 PM »
75f, that would be great, let me know what you can do.
