Author Topic: Pilot screw issue  (Read 1011 times)
Offline WFO
  • Will work for powerbands
Pilot screw issue
« on: September 07, 2008, 05:32:46 PM »
This is on a quad and i just rebuilt the carb and it has the spring on it but it keeps backing out after a few minutes of riding question is does anybody have any ideas how to fix this problem, and would thread lock work?
82 cb650 sc nighthawk - 78 kz 650 b
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
Re: Pilot screw issue
« Reply #1 on: September 07, 2008, 06:00:55 PM »
Is there an empty notch on the pilot screw like there should be an o-ring, or if there is an 0-ring, is it dry and shrunk?
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
Offline WFO
« Reply #2 on: September 07, 2008, 06:05:06 PM »
It's all brand new and i don't think it had a notch ( i will look at the old one)
« Last Edit: September 07, 2008, 07:49:40 PM by WFO »
Offline WFO
« Reply #3 on: September 07, 2008, 07:49:58 PM »
update: yes it has a groove for the o-ring but it's brand new.
KingCustomCycles.com
« Reply #4 on: September 08, 2008, 03:25:24 AM »
Get it adjusted and coat with blue rtv silicone around the top. It is removeable with your fingernail and seals nicely.  I also used to use fuel line over the needle valve on model aircraft engines when they would back out.  Same idea.
