SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Electrical problem
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Electrical problem (Read 656 times)
Bernhard1
Guest
Electrical problem
on:
September 07, 2008, 09:17:15 PM »
I have a 1975 CB750K5. Had been running well. Recently while on a ride all electrical shut sown and engine died. Pulled left side panel and noticed the main fuse (15A) was burned out. Replaced with a 7A (took the top one (of the three fuses in the box) and used it for the main. Bike started but no lights.
What would cause the main to go out like that all of a sudden while riding. Regulator or Rectifier problem? Can't ride until problem is fixed.
Logged
TwoTired
Really Old Timer ...
Re: Electrical problem
Reply #1 on:
September 07, 2008, 09:25:31 PM »
Hundreds of posts like this.
http://forums.sohc4.net/index.php?topic=2206.msg15960#msg15960
Logged
Bernhard1
Guest
Reply #2 on:
September 07, 2008, 09:57:12 PM »
Thank you. Will look into the fuse holder to see if there is corrosion. Hope that works.
Logged
TwoTired
Reply #3 on:
September 07, 2008, 10:00:39 PM »
Some oxidation is transparent, still resistive and generates heat. If your fuse is melting at the end caps, its heating from external sources and not blowing from over-current.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
Electrical problem
