Author Topic: Did the Honda Engineer Really Get Hung-up and Shot?  (Read 3543 times)
Offline Hope
  • How did I become an
  • SOHC member since '01
Re: Did the Honda Engineer Really Get Hung-up and Shot?
« Reply #25 on: September 10, 2008, 02:32:49 PM »
You should try to put plugs in a 03 Nissan Frontier.
I'll carry the scars to my grave.
Hint hint...
they make a special tool that comes with your tire tool kit that actually will help put the plugs in your frontier.  I changed the plugs in my 99 frontier - all but #6 - then found the tool they referenced in the owner's manual.  This will make your job much easier.
I also use the tool Honda provided to help put the plugs in my 550.
Owners manual?? [slaps forehead] Never dawned on me to look.
#6 was a little bi***. Used two swivels, a mirror and a magnet (to find lost wrenches).
Yep, my first try, I left the #6 right where it sat & just put up with a miss. I had those extensions & magnet & mirror just for #5, so I gave up on #6.  Even though I had the manual, I didn't know where this specialty tool was that they (the manual) referenced.  (They never said to look in your tool kit.)  duh
....AND I CERTAINLY WAS NOT GOING TO BUY THE SPECIALTY TOOL FROM NISSAN.  I figure that would run an easy $100 or so...  Anything with a Nissan stamp on it seems to!
So, from here on out, I am using the specialty tool provided in the tool pouch with the jack.  You should too!  ;)
Offline XN
« Reply #26 on: September 10, 2008, 10:01:13 PM »
You guys whine like little school girls  :D Chit you could dance in that area...
Try being 6' 250 lbs working under the instrument panel in a Lear 23 on a nice 80* day...
Or replacing a aux hydraulic pump in the hell hole of a Citation 500 with skydrol dripping on your face...
78 Honda CB750K
02 Yamaha V-star 650
02 Honda VTX 1800
« Reply #27 on: September 11, 2008, 04:54:00 AM »
.....or replacing a cam chain in a TX750. :D ;)
martino1972
« Reply #28 on: September 11, 2008, 06:14:21 AM »
to try and be 6' i will have to bend down......i'm 6'7".... ;)
eldar
« Reply #29 on: September 11, 2008, 06:17:37 AM »
To try and whine like you guys do, I will hang out with a group of high school girls all day! ;D
