Author Topic: New Life for CB550  (Read 4393 times)
joe_and_jeep
New Life for CB550
« on: September 10, 2008, 06:02:09 PM »
I think this would be the right forum.  Anyhoo...  I am starting with a Taylor Dunn utility cart.  Its electric powered, with a Ford 9in rear.  I'm pulling that out to put in a Honda CB550 motor and Yamaha Blaster swingarm.  Me and my little bro converted a XR350 into a trike 3 or 4 years ago so I'm cutting the rear out of that.
Offline Ecosse
  • Member #4139
    • My 550 walk around video
Re: New Life for CB550
« Reply #1 on: September 10, 2008, 08:09:20 PM »
Spend some time on this site!
http://www.3wheelers.com/
I really like cycle cars (think early Morgans) and you may want to submit your build pix to 3 wheeler.com as he has quite a database of trikes/3wheelers/cycle cars.
1974 CB550K
                                  Your 1%er name
comp
« Reply #2 on: September 11, 2008, 06:38:35 AM »
what are you using the electric stuff on ??
joe_and_jeep
« Reply #3 on: September 11, 2008, 11:13:39 AM »
Scrapping the motor and hanging on to the rear axle.  I'm just using the swingarm off of the tryke.
Offline fastbroshi
  • Puppet
« Reply #4 on: September 11, 2008, 11:54:12 AM »
   That doesn't soound like a bad project.  Those are decent carts, we had a couple of them at the Marine Corps Recruit Depot when I was stationed there.  We'd hook the rear end up to a hoist or just have a couple of us hold up the back end and burn 'em till we had slicks, then pray for it to rain.
Just call me Timmaaaaay!!!
Offline Hush
« Reply #5 on: September 11, 2008, 03:09:14 PM »
Looks like Martino removed the 550 engine from the frame!
Ever heard of removing the motor from the left side or are you using the cradle as support in the trike?
joe_and_jeep
« Reply #6 on: September 11, 2008, 04:07:58 PM »
I guess I should of been more clear last night.  I'm putting the 550 motor in the car, using the tryke rear axle and swing arm in the tryke.
comp
« Reply #7 on: September 11, 2008, 06:03:48 PM »
 those parts may be worth a few bucks
joe_and_jeep
« Reply #8 on: September 11, 2008, 07:18:36 PM »
Got the rear out and started mocking up for the engine.  Didn't get pics of that, got too dark.  The electric motor is junk.  The rear I am saving.  Never know when I will build something odd, like a small block in a golf cart and need it.
Offline Ecosse
  • Member #4139
« Reply #9 on: September 11, 2008, 07:26:11 PM »
He he heee... when I read the cart had a 9" diff, a v8 swap was the first thing to come to mind.
You evil person you! ;D ;D ;D
I'm at my computer cheering this little Frankenstein on.
1974 CB550K
                                  Your 1%er name
comp
« Reply #10 on: September 12, 2008, 01:12:21 AM »
got the brain working  ;D
Offline DarkRider
« Reply #11 on: September 13, 2008, 03:21:19 AM »
Just a random thought here...but one way you could have done this is retain the original rear set up and modify it to accept a driveshaft from the CB engine...then you could use the original electric motor for reverse.
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
Offline KB02
« Reply #12 on: September 13, 2008, 05:13:47 AM »
Oooohhhh..... Good idea....
This is going to be neat to watch.  ;D
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
joe_and_jeep
« Reply #13 on: September 13, 2008, 11:06:33 AM »
Good idea, but the electric motor is garbage.  I did however when I cut the motor out was leave the rear frame portion intact to mount the swingarm.
joe_and_jeep
« Reply #14 on: September 13, 2008, 12:48:47 PM »
Hehe...  Got motor???  Just doing a dry fit.  Some stuff needs clearancing.  Maybe by the end of the day I will have it mounted and the swing arm modded.
joe_and_jeep
« Reply #15 on: September 19, 2008, 05:42:52 PM »
I haven't had electricity all week.  Now I do  ;D
joe_and_jeep
« Reply #16 on: September 24, 2008, 04:21:12 PM »
 ???  Trying to wire it up.  I thought there was wires coming out of the points covers  ???
troppo
« Reply #17 on: September 25, 2008, 03:16:31 AM »
I know there should be, there is on my 750
joe_and_jeep
« Reply #18 on: October 05, 2008, 08:03:33 AM »
At a standstill...  Need exhaust.
