Author Topic: Will a 79 rear caliper fit on my 75f?  (Read 1705 times)
Offline Steve F
Re: Will a 79 rear caliper fit on my 75f?
« Reply #1 on: September 14, 2005, 01:29:18 PM »
Probably not.  The '77 used ComStar wheels, and the rotor offset was different, making the caliper offset different too (or vise-versa).  I tried using front calipers from a '77 on my '76 750F, and there was no way, unless I swapped out the wire spoked wheels with the comstars and the forks as well. So I'm thinking there are similar problems with the rear wheel as well.
« Reply #2 on: September 14, 2005, 04:01:21 PM »
That 77F front end will work with the 76F wheel Steve....it takes alot of work though.
LeoLegendATL
« Reply #3 on: September 14, 2005, 09:31:32 PM »
so a no go? anyone tried this, made it custom.  If not, where can I find a rear caliper?
