Author Topic: How to remove the two sunken cylinder head nuts  (Read 1342 times)
Offline wlh1950
« on: September 13, 2008, 12:50:33 PM »
I want to replace the head gasket on my 400F2 and have removed the rocker gear. Next is the cylinder head, all nuts are loose, except the two sunken ones near the plugs. They are rusted, rounded ans solid. There is no way I can remove them.. Has anyone an idea how to remove these two?
Thanks
Offline Mach5
Re: How to remove the two sunken cylinder head nuts
« Reply #1 on: September 13, 2008, 01:30:30 PM »
Try using an extractor. Find a drill bit a little smaller than the OD of the extractor. Drill into the bold about 1/4inch. Definately soak the bolt in some penetrant, then use the extractor to back the bolt out.
« Reply #2 on: September 13, 2008, 01:44:16 PM »
If you have rounded the nuts the only chance is a socket that will "hammer" on. If they are originaly 12mm i think a 1/4 or 3/16 whitworth works well
Offline Patrick
« Reply #3 on: September 13, 2008, 01:56:42 PM »
Craftsman has sockets designed to grab rounded bolts and nuts. You don't have to pound them on. They work very well - even when I use them. This won't be the last time they come in handy.
Patrick
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
« Reply #4 on: September 13, 2008, 02:37:23 PM »
Patrick
i'll second the craftsman nut removers  they work wonders
http://www.sears.com/shc/s/p_10153_12605_00952166000P
Offline wlh1950
« Reply #5 on: September 13, 2008, 03:50:06 PM »
Thanks for all the replies! I will try the drill first, as I already tried the other ones.
Offline Bodi
« Reply #6 on: September 14, 2008, 07:04:20 AM »
If you drill those studs, you'll be sorry. Replacing studs is a true PITA. Try anything else first.
Offline wlh1950
« Reply #7 on: September 14, 2008, 07:33:27 AM »
They are loose! A friend of mine managed in 30 minutes what I couldn't in weeks (no comment).
« Reply #8 on: September 14, 2008, 07:42:44 AM »
I do hope you is buying new Honda nuts---they come with a flange on them
Offline mystic_1
  • 1970 CB750K
« Reply #9 on: September 14, 2008, 08:31:18 AM »
How did he do it?
mystic_1
- John Augustus Shedd
Offline wlh1950
« Reply #10 on: September 14, 2008, 09:46:40 AM »
I will buy new nuts (I'll make a pic of the old ones). He did it as I already tried, with a chisel (don't know if that is the correct English term).
