Author Topic: 1978 CB550K- clutch ignition interlock?  (Read 886 times)
Offline beelsamin
« on: September 14, 2008, 07:54:49 AM »
The discoveries continue on my 3 previous owner cb550k:)
There are wires going from the clutch handle mount into the headlight nacelle,I'm assuming it's an ignition interlock,disengage clutch and start the bike.One of the wires is pulled out.I cannot see how the wiring is connected into the mount,is it just held by friction?There don't appear to be any screws to hold it in,and the Clymers doesn't show anything in the way of pictures apart from the wiring diagram.
Thanks
1977 Suzuki GT750
1972 Honda CB750 K2
1978 Honda CB550K
Re: 1978 CB550K- clutch ignition interlock?
« Reply #1 on: September 14, 2008, 10:16:15 AM »
From memory...
It is a fairly cheesy arrangement.
The switch body pushes out toward the clutch lever side (clutch lever removed).  Feed the wires through the hole in the housing.  If you are lucky, when the wire was pulled out, it straightened the contact/terminal.  Feed this back into the switch and then reform it so it makes contact with the small button out.  This completes a ground path so the solenoid will engage when the clutch lever is pulled in.
Offline beelsamin
« Reply #2 on: September 14, 2008, 02:01:05 PM »
Thank you,I'm always impressed by your knowledge,I mean that in the best way :)
1977 Suzuki GT750
1972 Honda CB750 K2
1978 Honda CB550K
