Author Topic: Tubeless tires on spoked wheeels  (Read 1020 times)
Offline DavePhipps
  • Reading the entire Hi-Perf forum
    • Hillside Technology
« on: September 14, 2008, 09:36:43 AM »
I just came across this last night when researching rims. I thought others might be interested.
http://pakbikes.net/PS1000LE/ALPINAWHEELS.html
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
KingCustomCycles.com
Re: Tubeless tires on spoked wheeels
« Reply #1 on: September 14, 2008, 09:53:05 AM »
I don't see a phone number to call so they can come get me, on a dark night in a remote area, and put me up in a hotel for free, when they go flat.
Offline CBGhia
« Reply #2 on: September 14, 2008, 09:57:57 AM »
I have seen a few versions for ducati motorcycles, at $3k per set.  I'll just buy tubes.   You can get a whole ass load of tubes for 3k.
« Reply #3 on: September 14, 2008, 10:03:25 AM »
BMW has used it on a factory level for years...as has at least one wirewheel company for cars..
BMW does recommend getting a dealer to redo if you change rims.
Basically boils down to getting your rims prepped, should have a deep bulge or dimple...then using a sealant that will stay on there..
« Reply #4 on: September 14, 2008, 10:06:38 AM »
I just hate new ideas...... ;)
Offline purf_man
« Reply #5 on: September 14, 2008, 12:08:58 PM »
some of that is also the design of the rim itself.  I think they just use a rim strip with a sealer on the spoked section but the bead of the rim is a different design that helps retain the bead.
i have the factory alloy wheels on my RD400 which are a tube type.  since they do not have an inner lip to retain the bead you have to run tubes (which is a total pain in the ass)
1975 CB550
1978 RD400
« Reply #6 on: September 14, 2008, 12:11:16 PM »
King..Yeah, we can tell by the pics of your bikes!! ;D
>>>>>>>>>>>>>>> running>>>>>>>>>>>>>>>>   ;)
Those hubs are the shiznitz.. I will build a set for my bicycle, and my 750..they look..soooooooo...cool.
Offline DavePhipps
« Reply #7 on: September 14, 2008, 06:51:31 PM »
If I could fit a set of nice tubeless radials on my bike with these I would do it (if I  wasn't so  broke).
Frankly a flat on a bias ply and a radial are two very differeent creatures.
Bias ply flop around when flat. Radials are so stiff it just seems like the tire pressure is low.
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
