Author Topic: Honda CB900 Questions.  (Read 9161 times)
Offline DarkRider
« on: September 15, 2008, 06:58:15 AM »
I have learned of a Honda CB900C for sale cheep ($200) however it has a problem that could very easily be a deal breaker unless its fixable. From the sounds of it one of the bearings on the connecting rods wore out allowing the con rod to make contact with the block. Now im not exactly sure if it put a hole in the block or not. The question is this...Is this repairable or would i be better off looking for a complete engine to replace the damaged one? Yes i know the bike is a DOHC but its a problem that could easily befall an SOHC as well..
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
Re: Honda CB900 Questions.
« Reply #1 on: September 15, 2008, 08:33:24 AM »
There would be no way to know without a complete teardown and inspection.  Anything is fixable with enough parts and time.
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
Online bryanj
« Reply #2 on: September 15, 2008, 08:34:16 AM »
Any Honda that takes a rod bearing will need as a minimum:-
Crank
Rod
Shells
gaskets etc
So to be honest a different motor would be the easiest way to go
Offline 333
  • Time for change
« Reply #3 on: September 15, 2008, 02:01:54 PM »
But it's a ten speed!  Worth it.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline DarkRider
« Reply #4 on: September 15, 2008, 03:51:35 PM »
Thats how im looking at it..I do have access to a Honda CB1000 engine but im not sure if it was from a CB1000C or not. If it was that would make life a heck of a lot easier...Does anyone know if many parts interchange between the CB900 and the CB1000?
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
Offline Aaron J Williams
  • Old Biker
  • Member # 725
    • Dude's Garage
« Reply #5 on: September 16, 2008, 07:12:18 AM »
The top end should be the same but I think the 1000 had a different trans and maybe was chain drive, not shaft. I don't know if it would bolt into the 900 frame, due to the lack of sub-transmission. CB900s are very nice bikes and they are worth some money too. I've been looking for one for some time and even the non-running ones go for a grand around here. :'(
There are old bikers and there are bold bikers but there are very few old, bold bikers.
Quote from: Gordon
Not doing what you can to make your bike ride-able during the best riding months of the year kind of defeats the purpose of owning it in the first place.
Offline DarkRider
« Reply #6 on: September 16, 2008, 09:44:08 AM »
I have found out there is a one year only CB1000C with the same sub trans as the CB900..I gotta check out the spare engine we got in the shop because there is a CB1000 engine there..though i dont know if it is a C...
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
Offline CBJoe
« Reply #7 on: September 19, 2008, 10:02:31 AM »
You might check into the swingarm requirements for the CB1000 engine to final drive.
A buddy of mine here at work is on his 3rd CB1000 rebuild (all in the last couple years) and is quite familiar with the differences betweent the two bikes.  He says that most everything is interchangable, but he remembers something wierd with the swingarm between the two.  Best bet is to use Service Honda or other resourse to compare part numbers.
Cheers....Joe
'07 Bonneville Black
'65 CB77
'66 CM91 (C90'ish)
Offline ofreen
« Reply #8 on: September 19, 2008, 05:29:43 PM »
Here is a sad fact about Japanese motorcycles.  They are rarely worth fixing if they have a serious problem.  Even if you don't pay much up front (even free), by the time you have it going you could just as well found another one in sound condition for less than you have in the repaired one.
Greg
'75 CB750F
  • Old Biker
  • Member # 725
    • Dude's Garage
« Reply #9 on: September 19, 2008, 07:20:13 PM »
Quote from: ofreen
And yet here we all are rebuilding and restoring 30+ year old bikes that cost more to fix now than the sold for new. Kind of makes you wonder about our motives, don't it? ???
Quote from: Gordon
Offline ofreen
« Reply #10 on: September 19, 2008, 09:36:57 PM »
[And yet here we all are rebuilding and restoring 30+ year old bikes that cost more to fix now than the sold for new. Kind of makes you wonder about our motives, don't it? ???
I understand your point, but I'm not talking about the same thing.  Darkrider has a line on a bike that apparently the conrod is hammering the case.  Lots of expensive damage is likely.   If he want a CB900, there are still decent ones around that have sound engines that would likely cost less than repairing the one he is looking at.
Greg
'75 CB750F
  • Old Biker
  • Member # 725
    • Dude's Garage
« Reply #11 on: September 20, 2008, 08:38:13 AM »
I wasn't talking about the 900 either, I was suggesting that your statement about jap bikes might not apply to the SOHC4s we all hold dear or that there are some jap bikes where cost isn't the only determining factor for repair.
For the 900 in question I would look at the cost to repair versus what the bike would sell for when repaired. A good running 900 Custom in my area is worth $2000-2500 unless it has a Hondaline fairing and luggage. I have seen dressed 900s go for up to $3600. If the bike could be bought as-is for $400 and an engine for another $400 (Two Wheel Heaven, a nearby yard has 2 of them for $325 each) You would have $800 invested. Let's say the engine can be changed in 10 hours (more likely 4-6 if you are skilled) and your labor is worth $40 per hour then your labor cost would be another $400 for a grand total investment of $1200. That gives you an $800 clear profit if you sold at $2000, and a $1300 clear profit at $2500. That's a possible return on investment of 60% to 100% after you get paid $40/hr to fix the bike. It's a gamble, for sure but it's a gamble I would take.
Quote from: Gordon
Offline JSGAuto
« Reply #12 on: September 22, 2008, 12:20:17 PM »
The 1000C and 900C are both shaft drive and will interchange.
Check out www.cb750c.net
Just another forum, but with DOHC folks.
Enjoy,
Jim
1971 CB450 Future CR Project
1974 CB550 9K mile Beauty!
1974 CB450 "Beach Bike"
1979 CB750F Basket Case
1980 CB750F Rat bike (daily ride)
1982 CB750F 5k Miles Stocker
1982 CB900F Stealth Bike
