Author Topic: for those of you with clipons...  (Read 1502 times)
Offline uwjberg
« on: September 15, 2008, 09:18:20 AM »
how does it look/feel with the headlight mount also on the fork? seems to me that either the headlight would have to be mounted lower to make it comfortable. or just a different bracket for the headlight. i'm beginning to wonder if i should have gone with clubman bars... any thoughts?
Offline Triffecpa
Re: for those of you with clipons...
« Reply #1 on: September 15, 2008, 10:04:55 AM »
clubman bars are simpler and cheaper and get you about the same riding position.  The down side is that they aren't as adjustable as the clipons.  If you go clip ons, then you'll likely want to modify your upper triple clamp to get rid of the handlebar clamps.  Also, if you use one of the aftermarket fork ear sets, they are angled so that you can mount them one way or the other to get your headlight positioned right where you want it.
Try the clubmans first and make sure that you like the riding position.  Then go for clipons and mod everything to make for a clean install.
Tracy
Offline uwjberg
« Reply #2 on: September 15, 2008, 10:37:13 AM »
that's the problem - i already bought the clip ons. maybe i'll see what they look like and go from there.
Offline pampadori
  • slingshotcycles.com
    • Slingshot Cycles
« Reply #3 on: September 15, 2008, 10:39:39 AM »
clip ons can be adjusted to not hit your tank when you lock the bars one way or the other.
But you will need to ditch the stock headlight ears and get something that exposes some of the fork tube to mount the clip ons to.  I like the look of a bike with a low headlight so this is actually another benefit of going with clip ons, you can lower the headlight on the forks more.
www.slingshotcycles.com
brake hoses and more!
SOHC4 is your coupon code for 15% off!
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #4 on: September 15, 2008, 10:47:34 AM »
get some aftermarket headlight clamps and put the headlight wherever you want.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline KB02
« Reply #5 on: September 16, 2008, 04:40:13 AM »
You can also lower the forks in the clamps (thus lowering the front end a bit) and mount the clip ons above the triple tree. Slightly higher sitting position for you and you can keep the stock headlight mount.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
