Author Topic: Honda CBX has anyone ever seen one  (Read 41224 times)
Offline GroovieGhoulie
  • I have to return some videotapes.
Re: Honda CBX has anyone ever seen one
« Reply #25 on: September 17, 2008, 05:54:51 AM »
The '79 CBX is on my short list of "Bikes I will own before I die".  The '79 is the most desirable to me.
Reasons:
I prefer the "standard" Comstar instead of the reverse comstars.
150MPH Speedo.  The rest all had the retarded Federal 85MPH speedo.
Hottest cam
Working ignition advance mechanism ('80 model bikes ignition advance was identical, but units malfunctioned, dropping the bike 20hp.  If the factory recall has been done, it's supposedly a non-issue, but some folks still maintain that the '79 advance is hotter.)
Five-circuit carbs versus four-circuit.
From what I gather, the '79 and '80 bikes, (but ESPECIALLY the '79), were max-HP hot-rods with tons of power (105hp), iffy brakes and marginal suspensions.  It was all about that incredible engine.
The later '81-'82 (touring) bikes were detuned down to 85-90hp, but "broadened in the mid-range" to be more "driveable".  However, they got MUCH better suspensions, with the Unit Pro-Link monoshock rear end, and a vastly improved front fork.  The brakes were internally vented as well, like a car's, and were also improved.  The fairing and luggage also made them livable daily.
The faired bikes are arguably better riders, but screw all that, make mine a '79.  However, prices reflect that taste, (EVERYBODY wants a '79) and good, clean, original, low-mile, unmolested (is there any other way to buy a bike?) '79s command a premium, even compared to the "similar-spec" 1980 bikes.
Offline crazypj
  • I'm brill, me
« Reply #26 on: September 17, 2008, 09:55:14 AM »
I worked on a bunch of them 'back in the day'
 Wasn't any fun doing a cylinder head though, several days to get 24 valves right.
 Nice bike, bit heavy, incredibly smoooooth.
 not too difficult to work on, easier to loosen drive chain and front/top engine mounts to get carbs off (cant remember if it pivots on top or bottom engine mount, I think lower one?)
PJ
Offline my78k
« Reply #27 on: September 17, 2008, 10:48:42 AM »
3 on my local CL right now...this is the most current and is an 82 in white with the fairing etc
http://toronto.en.craigslist.ca/tor/mcy/826574998.html
1982 Honda CBX 6-Cylinder Motorcycle - $4499 (Danforth & Woodbine)
Reply to: sale-826574998@craigslist.org [?]
Date: 2008-09-04, 3:37PM EDT
1982 Honda CBX 6-Cylinder Motorcycle 66,000 km
Immaculate condition, with fairing, saddlebags, full cover, and workshop manual HAVE to sell it - Insurance just expired Call 416-407-6049 please
it's NOT ok to contact this poster with services or other commercial interests
« Last Edit: September 17, 2008, 10:51:29 AM by my78k »
Offline my78k
« Reply #28 on: September 17, 2008, 10:50:52 AM »
Here is the other not sure if it is still for sale due to it being a couple of weeks old (at the very least you can follow the link to the pics: http://toronto.en.craigslist.ca/tor/mcy/818946743.html
1979 Honda CBX excellent condition 49K - $6000 (downtown)
Reply to: sale-818946743@craigslist.org [?]
Date: 2008-08-29, 8:35PM EDT
i need cash for a new kitchen, so i'll let you steal this baby from me!
beautiful and original.
i'll include a recent appraisal @ $6200...compare at $10k!
okie
« Reply #29 on: September 17, 2008, 11:09:41 AM »
Well, GroovieGhoolie, you are correct about some of the '79/'80 changes, but there are some positive ones too.
Improvements in the '80:
+ much improved air assisted forks
+ Showa FVQ adjustable-damping shocks with 30 different damping/spring preload combinations
+ a stronger swing arm that pivots on needle and ball bearings rather than bushings
+ a frame with more substantial gusseting
+ a wider rear rim
+ larger oil cooler
+ A "vacuum-operated" petcock that hopefully prevents the engine destroying hydro-lock that could happen on the '79 if you forgot to turn the fuel OFF
+ tail-section storage compartment that locks
+ more even power delivery with no lean spot glitches that are present in the '79
+ and last but not least, mine was made in Marysville Ohio (NOTE:  Not all of the '80's were made in Ohio.)  This is the first American bike I have owned since my old Cushman in 1961.
The '80 doesn't  have as much horsepower and isn't as fast or quick as the '79, but if fast and/or quick was what I wanted any current 600(or larger) crotch rocket will absolutely humiliate the CBX.  I have owned both a '79 and an '80 and I like my '80 better.
Now, about that ridiculous 85 MPH speedometer.  I NEVER go over 85.  And I'm sticking to that story. ;) ;)
« Last Edit: September 17, 2008, 11:12:10 AM by okie »
« Reply #30 on: September 17, 2008, 01:55:33 PM »
I don't argue ANY of that.  The '80 bike is superior to the '79 bike.  I would hope it is, since if it wasn't, Honda clearly doesn't learn anything between model years and, well you get the point...
As it is, I want the '79 DESPITE all the "shortcomings", since it's marginally hotter and faster than the later bikes (in the CBX range).  While I know a modern 600 will SPANK it, knowing that I own the hottest version of a vintage bike, that is important to me, ergo, I want the '79.
That's why I bought a Sandcast 750: it's the hottest (no-compromise) factory version of the SOHC 750 out there.  And it's why I want a first-year CB350 Twin, since it's hotter than the later versions.
When it comes to VINTAGE Hondas, the first-year bikes are always the hottest (and hence, most collectible), so I want them.
Personal failing, what can I say...
Offline Blueridgerunner
  • CB650 no longer, but do have an 87 GL1200
« Reply #31 on: September 17, 2008, 02:04:34 PM »
A buddy and I used to race one with a nitrous oxide setup. Insanely fast until he missed a shift and threw a rod right through the case  :'(
Said James "In my opinion,  there's nothing in this world, beats a '52 Vincent and a red headed girl"
Laissez les bons temps rouler
Offline grumburg
  • 74550, 76400F, 72 750 67S90, 68CL90, 65 s65 66 x6
« Reply #32 on: September 17, 2008, 05:26:24 PM »
A friend of mine owned a Honda dealership. In March, 1985 Honda offered new 1982 CBXS to dealers for $1585, but they had to take 5. I bought one at cost and rode it for 2 years and sold it for $2000. Parts and service were outrageous and dealers would not touch them after they were out of warranty. Although they looked cool, I just never warmed up to it. A GS1100, CB1100, or KZ1000 were a lot less complicated. Granted, 82s were probably the least desirable, but never feel they lived up to the hype.
Fonda Honda
Offline hoodellyhoo
  • CB350F
« Reply #33 on: September 17, 2008, 08:18:00 PM »
Reading this makes me wish honda would build a bike like this again. They used to be the innovators, always one step ahead of the other maturer's. They have become such a conservative company these days, where's their b@##s? When will they ever make another bike like the CBX that is so far ahead of everyone else, something that screams, "Ha Ha! look what we can do! Take THAT!".
Offline Sporkfly
  • The frosty rider
  • Mmm, Guinness
« Reply #34 on: September 17, 2008, 08:45:32 PM »
Also, look at the Goldwing! The 1972 prototype is a monster with an opposed 1470cc 6 cylinder engine. The Honda engineers really just wanted to see how big they could go in the 70s. Wish they would push things like they used to.
« Last Edit: September 17, 2008, 08:47:22 PM by Sporkfly »
1977 CB550K
1979 CX500
1976 Suzuki GT500 Titan
Offline Shenanigans
  • Right turn?
« Reply #35 on: September 17, 2008, 09:02:19 PM »
Imagine if Honda made the goldwing into a "sport bike" instead of turning the naked standard into a tourer. The early naked goldwings were very attractive bikes.
I think the new V-5 VFR is about as adventours as they have been for a while ::)
Offline KB02
« Reply #36 on: September 18, 2008, 04:44:38 AM »
I saw the coolest looking CBX chopper once. Spikey would have been in love. There were spires all over that bike. The kind of thing where it went beyond tasteful, it went beyond tacky, and actually somehow landed back in the land of Cool. The guy riding it knew how to use his right wrist, too.   ;D
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #37 on: September 18, 2008, 05:17:51 AM »
dids - you are clearly too young to have been around at the time (  :o ), but if you hang around any of the classic bike events in Kent (or even go as far as Box Hill or the Ace Cafe), you are bound to find one sooner or later. The owners will talk to anyone who is interested!
There's one here in Reading that the guy brings out two or three times a year for classic bike shows and the Xmas Toy Run.
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
Offline markjenn
  • CB750K1, CBX, RC30
    • Whizmo and Gizmo
« Reply #38 on: September 18, 2008, 08:30:17 AM »
Here's my 79.  I've owned it for fifteen years now and have had essentially no failures.  If you keep up with the maintenance, they're no big deal.  I'd rather do a valve check on this bike than my FJR.  I'd guess mine is worth $10K or a little better.
- Mark
Offline my78k
« Reply #39 on: September 18, 2008, 08:37:56 AM »
Wow...that is a nice CBX!
Dennis
Offline edbikerii
    • Gallery
« Reply #40 on: September 18, 2008, 08:48:14 AM »
Thut shure is purdy, Mark!  I wouldn't stick my nose up at one.
I saw a real nice one at the local shop the other day, too.  Beautiful bikes.
- Mark
SOHC4 #289
1977 CB550K - SOLD
1997 YAMAHA XJ600S - SOLD
1986 GL1200I - SOLD
2004 BMW R1150R
Offline KB02
« Reply #41 on: September 18, 2008, 09:45:36 AM »
Check out this link for some more Cool CBX's.
I love that top Martin Framed one!!!
http://www.motorcyclistcafe.com/forums/showthread.php?p=28604
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Offline Shenanigans
  • Right turn?
« Reply #42 on: September 18, 2008, 12:09:39 PM »
Look at the header pipes on the 3rd one down! beautiful! :o
Offline speedy gonzalais
« Reply #44 on: September 18, 2008, 01:18:17 PM »
- Mark
Thats exactly the cbx im looking for the newer shapes and models dont apeal to me but the 79 has got style
Il be going to some classic shows when im satisfied with the 650 steve i might even see if i can make it north at some point
82' C90
87' yamaha T80
79' CB125T/CD200 project
82' CB650z
80s kawasaki ae50/150cc project
92' Suzuki GSXR600
80' CB250N
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #45 on: September 18, 2008, 01:23:03 PM »
Here's a pic of the 'important' part of one that was at the Stockridge meet last year.
« Last Edit: September 18, 2008, 01:24:38 PM by Bob Wessner »
Offline Ecosse
  • Member #4139
    • My 550 walk around video
« Reply #46 on: September 19, 2008, 05:42:48 PM »
Found this on the Motorcyclist Cafe link. :-\
1974 CB550K
                                  Your 1%er name
fuzzybutt
« Reply #47 on: September 19, 2008, 06:33:42 PM »
i love the rc166 replica cbx, wonder if i should try building one...............................
Offline CBJoe
« Reply #48 on: September 19, 2008, 07:31:34 PM »
It's been said before but I'll say it again....  I think I just threw up in my mouth  :o  (Speaking about that chopper)
'07 Bonneville Black
'65 CB77
'66 CM91 (C90'ish)
Offline Shenanigans
  • Right turn?
« Reply #49 on: September 19, 2008, 08:49:54 PM »
What are you talking about, that chopper is amazing! In what other time in history have the style of bikes got THAT outlandish. Its ridiculous and I love it. Someone needs to save a few of those time capsules before they all get 'restored" :'(  I would think that around the time these bikes were new there were more customized ones rolling around than stock. If only I was around to see them :D
