Author Topic: Bead blast crancase covers?  (Read 1950 times)
Tomfl57
« on: September 14, 2005, 05:59:09 PM »
Has anyone tried bead blasting the crankcase covers on a CB?  I put a friends aluminum Triumph (car) intake manifold in our shot blaster and it cleaned up real nice.  I was wondering what my covers would look like if I popped them in there for a few minutes.
Re: Bead blast crancase covers?
« Reply #1 on: September 14, 2005, 06:41:27 PM »
They will look matte grey.
« Reply #2 on: September 14, 2005, 06:54:22 PM »
Two is correct. Once you knock the white crap off with the beads, you can polish them it to whatever level you want. Sanding may be better since u will smooth them at the same time. The polish up real nice if you use the right tools.
Offline Jonesy
  • Shop Rat
« Reply #3 on: September 14, 2005, 07:35:19 PM »
Some restoration books recommend vapor blasting- with water being the abrasive carrier rather than compressed air.
Offline kghost
« Reply #4 on: September 14, 2005, 08:03:38 PM »
I bead blasted mine before they were powdercoated.
Twotired is about right, they look grey.  ;D
Stranger in a strange land
Offline Bodi
« Reply #5 on: September 15, 2005, 08:11:35 AM »
I had some engine pieces lying around waiting to be cleaned. One day I saw a truck in the parking lot across the road depainting a Corvette so I asked the operator if he could do my engine stuff. He was using soda - baking soda powder, it is gentle enough not to eat the fibreglas body. He did my covers and the finish was excellent, no real abrasion of the metal but the crap and old clearcoat completely removed. He said they also did dry ice blasting, similar effect to soda but no dust problem (except for the removed old paint or whatever) and much more expensive.
The nice thing about soda is that it's water soluble, so washing the parts removes all the "abrasive" unlike bead or sand blasting where getting the crud out is a nightmare.
Offline Steve F
« Reply #6 on: September 15, 2005, 09:44:11 AM »
I agree with BODI, that the clean-up is a real PITA when using glass bead.  Problem with most blasting material is it's too aggressive, and causes problems with aluminum alloy.  The stuff tends to get stuck in the tinyest of places, threaded holes, and screws up finely machined surfaces, and can even distort the parts.  I would recommend either the soda blasting as mentioned before, or plastic media.  I had my engine plastic media blasted, and it came out perfectly bare of all paint and crud, and the base metal was not harmed in any way.  It will, however, mess-up any palstic or rubber parts if not careful, or when used with too much air pressure.
« Reply #7 on: September 15, 2005, 04:32:27 PM »
I f you do bead blast screw bolts into all thtreaded holes and tape off holes(2 layers at least) that lead to the main oil galleys. Blow the pieces off with high pressure and wash the pieces in hot soapy water. Blow out several more times. The baking soda is good but if you have the blast cabinet on hand.......
