Author Topic: Spray Paint Brand?  (Read 2357 times)
Offline bikerboycb650
  • And YOU must be the Monopoly guy!
Spray Paint Brand?
« on: September 18, 2008, 08:23:54 AM »
Hey guys,
      What brand of Spray paint do you use? What colors do you recommend for primer? I'm about to paint mine and just wanted some suggestions.
Offline Sporkfly
  • The frosty rider
  • Mmm, Guinness
Re: Spray Paint Brand?
« Reply #1 on: September 18, 2008, 08:31:23 AM »
Mmm, rattle cans.
Green (self etching) primer is what I use. For paint, I like duplicolor. I think duplicolor is the main recommendation you'll get.
1977 CB550K
1979 CX500
1976 Suzuki GT500 Titan
Offline Johnny5
    • CB350F build thread
« Reply #2 on: September 18, 2008, 08:33:52 AM »
I've had real nice results with high temp duplicolor for doing side covers.
www.kerosenecycles.com
1971 CB350
1973 CB350F
2006 Harley Springer Classic
« Reply #3 on: September 18, 2008, 08:36:33 AM »
oh... so no Krylon? Where can I find Dupli-Color?
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
« Reply #4 on: September 18, 2008, 08:38:09 AM »
Autozone carries a good selection of Dupicolor.  Might be a different auto shop depending on your location.
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
Offline Sporkfly
  • The frosty rider
  • Mmm, Guinness
« Reply #5 on: September 18, 2008, 08:40:04 AM »
I have had bad luck with Krylon. It didn't want to completely dry/cure so I had some nice tacky paint that easily scraped away, even after a week or two.
1977 CB550K
1979 CX500
Offline Triffecpa
« Reply #6 on: September 18, 2008, 08:42:21 AM »
+1 on Duplicolor
They make a "sandable primer" in black and red and grey.  Then you'll want to use their "primer/sealer" before you top coat your prep work.
Tracy
Offline Caaveman82
  • Zippo
  • That'll do pig. That'll do.
« Reply #7 on: September 18, 2008, 08:56:53 AM »
Duplicolor is definatly the way to go. I use it for priming rust spots on the folks cars. I also use it on my bike. I use Sikkens automotive paint for color but that is just because I work in a place where I have access to all the painting crap I need, but yeah any duplicolor is good rattlecan material.
Autozone, O Reilley's, I believe Advance Auto Parts has it. No more Checker or Kragen lol, big O bought them out.
« Reply #8 on: September 18, 2008, 08:58:59 AM »
Wow, I never heard of it before, but I will give it a try. If you guys like it it must be good. Saves me the troble of doing the job twice.
Offline Johnny5
« Reply #9 on: September 18, 2008, 09:09:41 AM »
I even found Duplicolor at Meijer's. It's good stuff.
1971 CB350
1973 CB350F
Offline wildcatmahone
  • Poseur
« Reply #10 on: September 18, 2008, 10:02:48 AM »
Rustoleum Professional....5 bucks a can from Lowe's.
Offline ColinMc
  • There aint no pickle like a super pickle...
« Reply #11 on: September 18, 2008, 10:57:33 AM »
Duplicolor and Krylon are actually made by the same company...but yes they are different paints lol.
I've never had any problems with Krylon...as a matter of fact I did an entire RX7 temporarily with their semi-gloss black and it came out fantastic. No issues with dry times or anything. I even keep a spare can around for small brackets and stuff I don't want to have to get my paint gun out for.
EDIT: Any NAPA store will also carry both.
1976 CB750K - Cafe Project...taking forever
1984 Honda MB-5 - MB-8 conversion in process
2001 Ducati 748 - Built 996 motor sleeper
Offline BIKE
« Reply #12 on: September 18, 2008, 11:11:54 AM »
Wait, you guys are painting your bike's tank and side covers with this stuff?  I'm curious, what do the finished products look like?
Pics?
1975 CB750 K5
1977 CB750A
Offline Caaveman82
  • Zippo
« Reply #13 on: September 18, 2008, 11:42:08 AM »
I did the side cover, the chain guard, the handle bars the rear fender and back of the head light with just a black duplicolor high temp primer, yes i powder coated it after but the flat black look was almost better.
« Reply #14 on: September 18, 2008, 11:43:37 AM »
Yeah me also, some pics would be nice.
Offline SHORTROUND
« Reply #15 on: September 18, 2008, 01:01:30 PM »
Pics?
when using duplicaor the secret is in the clear.
1 light coat
2 heavy coats
wet sand 2000 grit
1 heavy coat.
Offline Triffecpa
« Reply #16 on: September 18, 2008, 02:09:24 PM »
My problem with Krylon isn't so much the paint as it is the spray tip that they put on their cans.  It makes a quite narrow fan pattern so that it's hard to cover larger areas with even coats of paint.
The Duplicolor spray tip has a much wider fan pattern.
TR
« Last Edit: September 18, 2008, 02:11:54 PM by Triffecpa »
Offline BIKE
« Reply #17 on: September 18, 2008, 07:33:10 PM »
1 light coat
2 heavy coats
wet sand 2000 grit
1 heavy coat.
So you do all of this with store-bought duplicolor.  Hmm.....Sounds interesting.  I may have to do some trial work with this stuff.
How many coats of the paint do you lay on?  I assume by clear you mean just a clear coat?
1975 CB750 K5
1977 CB750A
Offline Sporkfly
  • The frosty rider
  • Mmm, Guinness
« Reply #18 on: September 18, 2008, 08:40:42 PM »
I won't argue that! It may have been a defective can or just the type of paint I had (I can't remember at this point). Anyway, one bad experience gave me enough reason to stick to the Duplicolor.
TR
+1 on that!
Pretty nice job that.
1977 CB550K
1979 CX500
  • Poseur
« Reply #19 on: September 19, 2008, 12:31:02 PM »
Well what are you spraying? Just so you know Krylon and Duplicolor aren't fuel resistant.
Offline cadaver
« Reply #20 on: September 19, 2008, 02:55:56 PM »
was just wandering how long do you wait till you spray the clear on ? till the paint cures or just till it gets tacky? thinking about doing this to my tank till i find the one that i want to order.
Offline kslrr
« Reply #21 on: September 20, 2008, 10:35:17 AM »
I think you need to wait 'till it cures.  Otherwise the clear cote will not let the color cote cure completely.
        1981 CB650 engine
Then 1972 CL175
        1964 Yamaha YGS-1T
Offline DavePhipps
  • Reading the entire Hi-Perf forum
    • Hillside Technology
« Reply #22 on: September 20, 2008, 10:45:50 AM »
Too true (looking at splotches on tank shaking head)
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
Offline wardmoto
« Reply #23 on: September 22, 2008, 08:05:36 PM »
Dupli color is the best thing going in a rattlle can.  Preperation is 85% of the paint job...research on the net, there is so much info.  Tanks pose a different problem; as you will spill gas regardless of your intentions.  Rattle cans have no prayer as todays gas.... it contains a lot of nasty ass crap that does 40 year old parts/seals no good.  Pretty soon these bastards won't run at all on the piss they pass as gas.  I have a 4 and a 5 year old and have 4 antiques out of 5 bikes...they will all go silent soon.  My kids come out every time I light one off...think about it....?!  They will go away ...and it will be sooner rather than later.  I almost recked my 90 civic Si into a vintage 750 with original pipes(4 into 4's with little rot)  I saw the paint, the seat, the tank and the original gators on the forks.  I am in uniform(law enforcement...don't hold it against me) and trying to figure out how I can offer to buy this steed after 15 seconds of watching it run.  Meanwhile the poor bastard thinks I am a dickhead cop trying to jam him up for something....in reality , I want a red light long enough to ask him to sell it to me!  These bikes are aging exponentially with respect to our current perspective of time...don't let them go...ashes to ashes....we will all end up from whence we came.   Sorry...don't mean to be so miserable.  My work is chalenging at best; it can beat you down if you let it...apparentley I have let it!  Jesus, what was the question????  Been dormant for a while, perhaps I should go back to that status...you guys rock....Bryan
03 Suzuki SV 1000S
86 Suzuki GS 550ES
72 Honda CB 350K
72 Honda CB 350F
72 Honda Cb 350F cafe
Offline XN
« Reply #24 on: September 23, 2008, 12:04:43 AM »
I think I'm going to buy some of this clear coat for my project!
http://www.eastwoodco.com/jump.jsp?itemID=21846&itemType=PRODUCT
78 Honda CB750K
02 Yamaha V-star 650
02 Honda VTX 1800
