Author Topic: 550 pilot screws  (Read 1328 times)
zoeyk9
550 pilot screws
« on: September 18, 2008, 04:49:16 PM »
The Clymer manual for my '78 550 says that the pilot screws are AIR screws, which meens that I turn them OUT to weaken the mixture. But if they are pilot screws wouldn't turning them out richen the mixture? What is correct?
Zoeyk9
Offline speedy gonzalais
Re: 550 pilot screws
« Reply #1 on: September 18, 2008, 04:51:58 PM »
i think out is more in is less
82' C90
87' yamaha T80
79' CB125T/CD200 project
82' CB650z
80s kawasaki ae50/150cc project
92' Suzuki GSXR600
80' CB250N
zoeyk9
« Reply #2 on: September 19, 2008, 06:08:01 PM »
Well Didds, I don't think my wife would agree with that!
Do you meen more fuel or more air?
Zoeyk9
Offline dnewman417
« Reply #3 on: September 20, 2008, 09:02:41 AM »
If it is a 1978 CB550K, then the screws are "idle mixture screws."  Turning them in richens the idle mixture and turning them out leans the idle mixture.
Offline Brian G
« Reply #4 on: September 23, 2008, 11:52:59 AM »
Newbie question here :-[. The carburetors in the Clymer manual show the screws on the side of the carb body. On the bike, however, there are no screws on the side. On the K4, are we talking about the brass knurled screws mounted vertically underneath the front of the floatbowl on the engine side?
They were all open about 2 turns, and the bike seems to be running lean - takes forever to warm up and spits back through the carbs at idle. I'd say the throttle response is a bit flat as well, but I've only owned the bike for a couple of weeks and have nothing with which to compare it.
It is fitted with what I believe to be a MAC 4 into 1, and the P.O. said he'd made no carburation changes whatsoever. Can anyone tell me if installation of this type of exhaust requires jet/needle/cutaway adjustments as a matter of course?
On another matter, in a response to my introductory posting a few weeks ago, it was mentioned that people here like pictures!, so here are a couple. No shortage of things to work on this coming winter  ;D
Hopefully this isn't seen as 'hijacking the thread'  :o
Best Regards,
Brian
1975 Honda CB400F
1978 Honda CB550K
1979 Honda CBX
1969 BSA Rocket 3
1976 Kawasaki KH400
2008 Kawasaki C14 Concours
apoji187
« Reply #5 on: September 23, 2008, 01:18:48 PM »
2 and a half out is about right, but you should really crack open those carbs and see if the idle jets are clean and check that float height.
Offline Brian G
« Reply #6 on: September 23, 2008, 02:26:30 PM »
They were all open about 2 turns....
Yikes  :o! So the screws were already 1/2 a turn rich and she stills spits! Guess a carb overhaul will be the first job this winter. I'd better do some plug chops before the snow and ice arrives too. Is the needle generally raised a notch and/or go up a size on the main jets when changing from a 4 into 4 to a 4 into 1? If so, I might as well do that while they're apart....
Thanks
1975 Honda CB400F
1978 Honda CB550K
1979 Honda CBX
1969 BSA Rocket 3
1976 Kawasaki KH400
