Author Topic: Clutch Specifications *Help* CB750K2  (Read 3260 times)
Offline Artfrombama
  • Card-carrying, board certified
  • CB750 K2
« on: September 18, 2008, 08:52:00 PM »
Did a search, checked the FAQ's, and the honda4fun.com site is down.
I need the minimum working thickness for the CB750K2 friction clutch plate and steel plate. Also need the clutch spring height.
Thanks! ;D
Halfassed machinist
Tinkerer/goof-off/Mr. Fix-it
CB750-2011594 Sunrise Flake Orange
CB750E2441103
Offline Clyde
Re: Clutch Specifications *Help* CB750K2
« Reply #1 on: September 18, 2008, 09:01:04 PM »
Friction disc thickness .. 3.42-3.58mm
0.1346-0.1409 inch
Wear limit 3.1mm (0.122 inch)
Clutch spring free length ... 31.94mm
1.257 inch
Minimum limit 30.5mm
1.20 inch
Steel plates in clutch
should be renewed if warped more than
0.3mm (0.012 inch).
The above has been copied from a Honda service manual
SOHC4 #1909
Honda CB750 K0(original and unrestored), K1(in pieces), K2(restored), F1(restored), 76 750a (awaiting restoration), 1966 Honda CB72
Suzuki GT750 1972 (restored), Kawasaki Z1 1973 (restored)
Offline Artfrombama
  • CB750 K2
« Reply #2 on: September 18, 2008, 09:18:47 PM »
0.1346-0.1409 inch
1.257 inch
1.20 inch
0.3mm (0.012 inch).
Damn!
Everything is within specs, frictions are .138-.142", spring height is 1.395"
Why would my clutch slip under full power in high gear? Engages right at the end of clutch travel. Adjusted the bolt until it lightly bottomed then backed off 1/8 turn.
Thanks for posting the info I needed, I owe you a beer! ;)
« Last Edit: September 18, 2008, 09:39:57 PM by Artfrombama »
Halfassed machinist
CB750E2441103
Offline Tower
  • Only at conception could I have been called a
  • My personal time machine: 1973 CB750K3
« Reply #3 on: September 19, 2008, 07:45:44 AM »
Reasons why slipping, from most likely to least likely, are:
1) Adjusted too far out
2) Springs are too weak - Replace springs
3) Worn clutch disks - Replace thin disks
4) Glazed plates and/or disks - rough up with 400 grit paper
5) Warped clutch plates - Replace warped plates
6) Poor oiling - drill more holes in centre, unclog passages
7) Crack in clutch pressure plate - Replace pressure plate
8 ) Worn clutch throwout mechanism - Replace clutch inner cover / mechanism
Clutch adjustment and to some extent condition of the clutch cable and throwout mechanism determine whether the clutch engages early (just as you begin to squeeze the upper lever) or late (upper lever almost touching the handlebars)
- Lube cable, adjust per manual ensuring 1/4 turn out from just touching
Edit: K2 was a transition year for clutch design, so ensure you have the right components for your particular clutch.
« Last Edit: September 19, 2008, 07:51:33 AM by Tower »
Offline Artfrombama
  • CB750 K2
« Reply #4 on: September 19, 2008, 08:35:31 AM »
Tower,
     I appreciate you taking the time for the in depth clutch troubleshooting guide. I will check those things this afternoon.
      When I took the cover off I was impressed that everything was in good condition (not wrecked by a ham-fisted mechanic like everything else) indicating either the case has never been opened or someone that knew what they were doing was there last.
     I did notice the first friction plate (furthermost from the center of the bike) was a different design than the others. Another thing I noticed that I felt wasn't kosher was the innermost friction plate was against the aluminum clutch drum. From my diagrams it appears a steel plate goes in first, then a friction.
     Could the wrong oil cause a slipping clutch? To get the bike running I used some cheap store brand 10W40 oil.
     I'll report back later.
Halfassed machinist
CB750E2441103
Offline Artfrombama
  • CB750 K2
« Reply #5 on: September 19, 2008, 02:30:15 PM »
Washed the parts up, the frictions were glazed up...Shiny as mirrors! A sheet of #80 emery paper on a piece of glass, sanded just enough to break the glaze. Sanded the steels too.
Back together and adjusted to the manual. All seems well.
Thanks to those that helped.
Halfassed machinist
CB750E2441103
Offline Tower
« Reply #6 on: September 19, 2008, 09:55:16 PM »
Choice of oil could make a difference.  The CB750's wet clutch works best with non-detergent motorcycle oils. Auto oils may not be the best as they could foam causing oiling problems.
The disk and plate configuration you described is correct for the early clutch designs.  i.e. disks were found at both ends of the disk/plate stack.  Also, the outer disk is larger so that it will fit properly in the wider basket.  Do not replace this outer disk with the smaller inner disks.
The early designs also had clutch inner baskets that were too restrictive in flinging oil out to the disks and steels.  If you find more than three holes in the grooves of the inner basket, your model is fine.  Fewer than three holes indicates a very early clutch design prone to burning and glazing.
I'm assuming that your clutch works perfectly now.
Offline Artfrombama
  • CB750 K2
« Reply #7 on: September 19, 2008, 10:11:42 PM »
Weeeelllll....
No more slipping in high but engages right at the last 1/2" of clutch lever travel. Adjusted exactly to the manual. Aggravating as %$#*& starting off because I have a bad hesitation just off idle.
Once I get moving it runs like a bat out of hell!
6 of the friction discs were the same, aluminum with straight oil grooves. One friction disc was steel and the grooves were more circular. Same shape and thickness.
7 discs and 6 steels.
I'll play around with the adjustment maybe Sunday.
Halfassed machinist
CB750E2441103
