Author Topic: Almost there...  (Read 868 times)
Offline Accolay
Almost there...
« on: September 19, 2008, 10:59:21 AM »
So, I've got the wheels back on, new chain, got the electrical system worked out etc on the 1977 CB550F
Only a few more things to do, and a few questions on how to do them.
1. I replaced the clutch cable, and now when I squeeze the clutch lever and put into 1st gear the rear wheel is moving and the transmission puts out a slight grinding sound. I've tried the clutch adjustment as per the manual. Wondering if I can do the same as on a 500 listed in this thread described by Hondaman http://forums.sohc4.net/index.php?topic=36228.msg374047 I wonder what I'm doing wrong?
2. Bleeding the brake system. The cables are new and MC rebuilt with new parts. Bought a speedbleeder nipple for the caliper as well. New seal on the caliper for the piston etc. Pretty sure there is a load of air in there somewhere, but it doesn't want to come out. The lever feels spongy and not hard. The pads are up against the rotor. Should I be doing something different because the system was totally dry? Clymers recommends squirting fluid through the system. What do you think?
3. The engine sounds like an old airplane when it's running. I'm guessing this is the result of my inexperience in adjusting  tappets?
1977 CB550F
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
Re: Almost there...
« Reply #1 on: September 19, 2008, 11:08:54 AM »
1. If the bike is on the center stand, the wheel will move when in gear with clutch pulled in.  Grinding noise might just be the gear lash.
2. I am having similar issues with the 650.  When I flushed and bled the system, Both calipers had no more bubbles but is still spongy.
3. Have you done a vacuum synch of the carbs?
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
Offline Accolay
Re: Almost there...
« Reply #2 on: September 19, 2008, 11:44:26 PM »
Thanks for the info about the rear wheel spinning. I was a little worried there. I think the clutch needs work anyway though, will probably save that until next year (or this winter).
I have yet to synch the carbs. I was going to do it almost last after I did the timing. I'll try that tomorrow and see if it gets rid of the noise.
As for the brake bleeding, I think I'm going to try pumping fluid through the system tomorrow before I go to work.
Thanks for the info.
1977 CB550F
